Whole House Auto-Shutoff Valve?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Shinshi, Feb 4, 2008.
  1. Shinshi
    Shinshi New Member
    Feb 4, 2008
    Alberta
    I am considering installing a whole house auto-shutoff valve. Essentially this valve would be connected to multiple water sensors throughout the house and shut off the main water supply if any leaks were detected. This is the valve I was considering...
    http://www.aartech.ca/product_info.php/products_id/631/FS1-1-4NPT.html
    This shut-off valve is 1 1/4" and the main water line coming into the house is 1". I was thinking of installing this right after the city water meter. Then daisy chain multiple sensors at the washing machine, dishwasher, icemaker & hot water tank and connect to this device. Then if a water leak was detected at any of those locations it would shut the water off to the house.
    My question is, would I possibly damage washing machine, dishwasher, ice maker, hot water tank & water softener if water was shut off and these units were in use? I wonder if the pumps would keep running and possibly even the heater in the washing machine and without water they would be damaged?
  2. construct30
    construct30 New Member
    Jun 16, 2007
    NorthWest PA
    The one thing I would worry about is the water heater. Also check with the manufacturer of other appliances. Normal washers and all should not be a problem, but some newer models could be. They make auto shut offs for the gas and electric water heaters as well as some appliances that work with those valves and sensors, however big $$$$.
  4. jadnashua
  5. Shinshi
    Shinshi New Member
    Feb 4, 2008
    Alberta
    My washer is a newer model Maytag made by Whirlpool, so I have not been able to find much information and determine if it could be damaged by a water shutoff valve like this.
    The WAG for the water heater certainly looks like a good idea! I may try that for the water heater instead.
  6. hj
    units
    There would be no damage, because the units have water level controls and if there is no water, the timer stops until it does fill.
Similar Threads: Whole House
Plumbing Forum, Professional & DIY Advice Whole house drain enzyme? Jan 26, 2017
Plumbing Forum, Professional & DIY Advice Whole House Water Filter HELP...super confused Dec 28, 2016
Plumbing Forum, Professional & DIY Advice Re-Plumbing Whole House Dec 26, 2016
Plumbing Forum, Professional & DIY Advice Whole House Backwash Carbon Filter Questions (bacteria etc.) Oct 25, 2016
Plumbing Forum, Professional & DIY Advice Adding a whole house water filter.... Oct 5, 2016
