whistling sound in kitchen faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cmwood70, Dec 15, 2008.
  1. cmwood70
    cmwood70 New Member
    Dec 15, 2008
    My kitchen faucet makes a whistling sound when the hot water is on. It did this two years ago and I replaced the faucet and it stopped. Now it is doing it again. I just don't understand...please help.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    There is probably a restriction of some nature inside the faucet causing the noise.
  4. Jay Mpls
    Jay Mpls Master plumber
    Sep 29, 2008
    Master Plumber /Sewer rat
    Minneapolis
    Well cmwood70 your plumbing is all against you!
    What sort of faucet is it? A simple cartidge replacement may do the trick.
  5. cmwood70
    cmwood70 New Member
    Dec 15, 2008
    It is a Price Pfister with built in pull out sprayer. I understand that it may be clogged with something, but it would be odd since it is fairly new and only makes the noise with hot water.
  6. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Since this happened to two faucets, you probably have gunk or mineral deposits that create a partial blockage. The faucet needs to be taken apart and flushed thoroughly. I would also flush your hot water line to try to get rid of any future crud.
  7. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    What key? :D
  8. hj
    noise
    The sound could also come from the shutoff valve under the sink and transmit through the piping.
  9. MaintenanceMan
    MaintenanceMan In the Trades
    Dec 10, 2008
    Maintenance
    Indiana
    I bought a Price Pfister with pull out sprayer a few years back when I replaced our counter tops and tiled the backsplash. It was whistling the second I started to use it. I put up with it for a few days before I had enough and took things apart to see what was going on. In the hose end, I believe its on the sprayer end but it might of been where it connects to the faucet body, was a little white restrictor (I still have it somewhere) to reduce the flow, conserve water, ect. Popped right out with a pair of needle nose pliers. Whistling stopped. Put it back in, whistling came back. So I took it out because I just couldn't stand the whistling. Pressure out of the faucet was fine so it worked for me.
    Here's a pic. That's the Price Pfister I have.
    [​IMG]
    Disclaimer: I'm not advising you to create a higher flow, anti"green", pressure washer here. It's totally your choice to modify your faucet in any way. Just relaying my experience. Had I of still had the box I would of probably just taken it back. I just couldn't stand the maddening high pitched whistle.
  10. Verdeboy
    Jun 12, 2006
    MM, it looks like you may have solved this.
    The $64,000 question, however, is whether the original faucet also was a PP w/ pullout sprayer or something similar.
  11. plumberdood
    plumberdood New Member
    Dec 16, 2008
    Check for kinks in the line. If the sound comes from the removable wand in the facet when you squeeze the trigger then the sound may be cause from a weep in the valve that controls the water flow in the wand. That is a common design flaw.
  12. flabiker56
    flabiker56 New Member
    Jan 6, 2011
    sc
    Had the same problem...took the little plastic washer out...noise gone...put it back ...noise back....took it out and left it out didnt notice that much of a difference in flow but the high pitched noise is GONE
Similar Threads: whistling sound
Plumbing Forum, Professional & DIY Advice Valve makes whistling or ringing sound Feb 28, 2009
Plumbing Forum, Professional & DIY Advice Moaning/Whistling sound coming from pipes Oct 19, 2005
Plumbing Forum, Professional & DIY Advice Whistling noise from water pipes Sep 20, 2016
Plumbing Forum, Professional & DIY Advice Whistling Gas Meter Feb 1, 2016
Plumbing Forum, Professional & DIY Advice Outside Plumbing Fixture humming / whistling Aug 24, 2015
