Whirlpool Water Heaters
Master Plumber Mark
www.weilhammerplumbing.com
I hate this brand of water heater....they are junk......
and something I just found out today from another
dis-satisfied LOWES --WHIRLPOOL customer...
un like a Rheem, Bradford White, Smith or State........
who stand behind their product 100%
with the Whirlpool brand
If you inherit a Whirlpool water heater when you buy a home
from someone and they claim it was just put in last year......and it
has a 12 year warranty......
you think you got that issue covered for a good long while, right???
Well, the warranty on this heater does NOT transferr to you !!!
Whirlpool will only warranty a leaking wter heater to the person
that purchased the heater.....not to the new occupant of the home....
Now ----Isnt that a dirty-- rotten --cheap assed way-- to worm out of their obligations to the consumer????
would you still buy one if you knew this???
Whirlpool Water Heater pictures
More posts on the Whirlpool Water Heater
Cass
No, I wouldn't buy one in the first place, but then I know better.
The bigger the corps get the less responsible for their products they seem to be.
Be glad you don't own a BMW. They charge the customer for shop rags, or better yet the Sprinter vans you see on the road, a fuel pump is almost $2,000.00 just for the part.
Wh
Sears does the same thing, as one of my customers found out when he bought a house, partly because it had a Sears lifetime water heater which failed a couple of months after he moved in.
Master Plumber Mark
sears
I was not aware of sears being such tight wads. too...
but for some people it just does not matter....
give me hot water and give tito me dirt cheap
to hell with the next guy or future problems
I have 4 40 gallon gas to install tomorrow......
two of them are for whhirlpol replacements, not covered under wrranty
Master Plumber Mark
The --NEW IMPROVED WHIRLPOL GAS HEATER---
I tangled with a new 2007 40 gallon gas WHIRLPOOL
heater yesterday.....
it has some very small improvements on it....
1. it now uses a normal thermo-coupling
2. it has a robert shaw thermostat on it with two wires that go down to a
high limit thermol switch on the side flame wall..
(something like the BRAD-FORD White)
The STUPID FOOLS did not make the air intake on the bottom of the heater any bigger than the old unit was..
so it will clog up with lint just like the old unit did.....
you would think that after a large lawsuit that probably cost them literally a hundred of milllion dollars.....
they would fire the enjeneers that designed that dog and get some new people to design the replacement
no they did not... its got to be a son-in -law of the president ...... running that department
So....
I changed the thermocoupling.....but it failed to stay lit after two days...
I could not get the thermostat from LOWES that
this unit needed for a week..
I was not sure wether I could install a Bradford White
thermostat on that unit ....dont need the liability
does anyone know wether they are inter-changeable???
and still I was not sure if it were the
thermostat or the little thermal fuse on the
side of the heater that was makeing it go out ......
So it is in my office now and I will take pictures of it
later this week.....
And a 50 gallon Rheem gas guardian is now installed in its place....
good going -----whirlpool ------
Keep up the good work.....
you are keeping me in business
Construct30
NorthWest PA
In most plumbing supplies or appliances it seems you have to choose a good brand or two that you can easily get parts for and if someone calls with a problem that is not your brand then offer to install one of yours or nothing you can do for them. I have waisted more time trying to find parts for some cheap piece of crap... who pays, usually the guy doing the job.
Smellslike$tome
Plumbing Company Owner
Birmingham, Alabama
www.themastersplumbingco.com
If you go to consumeraffairs.com and look for whirlpool water heater complaints (or google the latter and it takes you to the correct page) you will find more complaints than you would ever want to read.
Whirlpool does not manufacture anything. They stick their label on gas models manufactured by American water heaters and I think the electric models (which don't have nearly as many problems) come from US Craftsmaster or something like that.
I stopped using Whirlpool long before I knew about all the problems with their operation. I got tired of getting to the job and finding that the wh was all dented and beat up right out of the box. How am I supposed to sell something like that. I can't and wouldn't.
To all the DIYers and HO who want to install the cheapest thing you can find. Don't say we didn't warn you.
Cass
I just worked on a Cesspool Electric heater with the circuit board on the top of the tank that has a button, 2 dial adjustments and a indicator light that clicks when it is blinking.
Very fancy and impressive to a homeowner.
Well when the board goes bad you can't buy one anywhere. They have to be ordered.
So the home owners problem started Thursday and she will have hot water some time on Monday.
Cesspool strikes again.
Master Plumber Mark
CASS----The circuit baord....
I like the new name CESSPOOL it basically says it all
they might get that circuit board by monday....
it might show up by monday....the one I changed out
that was two years old was going to take 10 days and was gonna
cost the lady about $135 bucks becasue she was not the original
owner of the product...the heater came with the house so their crappy 12 year warranty
was void to her....
maybe it might fix the problems, but I would not
bet the farm on it.....
Usually its wise to change out the elements
and make sure nothing can short out that new
circuit board ..........or you will get to do it again..
duhhh..........
do you think that getting water on that circuit board might
short it out too..... water getting on a water heater....who would have known???
also their are some special "hi tech" sensors that are plugged in by
the elements that can go bad too.....
Who would make something this complicated and then pan it off
on the public????
Those people at American water heaters are smart cookies...
IN MY HONEST OPINION
The people in charge of American Water heaters ,
or Smith, or Craftmaster or Whirlpool or whoever owns the place now
simply have to be complete ---total 100% morons...........
JorjaGirl
Midland, TEXAS
In a WHIRL of POO....
I tried everything to make this whirlpool water heater work correctly and to no avail....it's just a piece of crap. Whirlpool is now sending out a new updated door with a coupling reset switch, that is supposed to fix the problem with the thermocoupling..... When I called Whirlpool about my thermocoupling there was a recording stating there was a CLASS ACTION SUIT AGAINST THEM ON THE FG OR FLARE GUARD MODELS. the website that you or your customer can go to get info or the claim form on all these thermocoupling that they have had to buy, new water heater, or if they had to do what I am, going to get a new door with the reset switch...then they can get reimbersed.... http://www.waterheatersettlement.com/ this site will direct you to the claim form. Let them know that they have to have it postmarked by June the 28th of 2008 to get anything back from whirlpool on this issue.
Master Plumber Mark
good luck with the thermal switch
I would like to hear what they send you when it finally arrives sometime late next week
unless they change the gas valve-thermostat and that stupid left hand threaded thermocoupling you will probably still be in trouble....
the new thermal switch will work for a while but unless your unit gets more air into it you will burn out that thermal switch in a short time...
their new design is no better than the old one
https://terrylove.com/whirlpool/
Jon4
Are you sure this is the case because I just bought a home and had to replace a two-year old Whirlppol hot water heater and I called the number on the heater and the call taker registered it and gave me a code number to take with me to Lowes for a refund or store credit. The call taker asked for my name, address, etc. and put it all in their computer system. I wonder if the owners of the home never registered the hot water heater when they bought it and that's why they're going to give me the refund.
I plan to return the hot water heater tomorrow and will let you know.
What do you think?
Master Plumber Mark
Dont ask--dont tell.....
If you get lucky enough to get one out of them
then perhaps someone has made an error...
I would not bring it up till you have the new one installed
I have dealt with dozens of them and heard the
same sob story from them all....
Recently , just last week I changed out a new Whirlpool heater .
...a 2007 which did not have a warranty to
the new homeowner....
The heater was installed in early February....
the lady bought the house in August.....
she claimes that was what was told to her..
when she called them.. and this was just for parts....
the new hi-limit switch on the side of the heater
was probably the problem
but their are no parts available in INDY to repair her
heater.....
So instead of having to wait about a week for parts to
be shipped we tore it out and installed a Rheem
here is a fun link to read...
American water heaters makes Whirlpool....
Unless they have changed their policy lately, I would assume
this information is still valid today.....
After talking to someone at Lowes last week,
please keep in mind that they still expect you to
use a wire brush and clean the screen
underneath the heater every 3 months......
even with the new 2007 units ----or your warranty is void....
(it states that somewehere in the fine print)
Put your new one up on bricks so you can get access to the screen.....
http://www.my3cents.com/showReview.cgi?id=14643
I will take pics of that heater and post them sometime soon
Cass
I wouldn't be surprised if there is another class action sute soon on these Cesspool Heaters.
Maybe some one will go after Low*s for Knowingly selling water heaters with known defects.
Master Plumber Mark
Smith owns american
Smith owns american that is the last I heard...
I think that they were even mentioned in that law suit
over this water heater.
they are trying to buy up all these little dogs and corner
the hardware store market
I can understand their point of view here.....
Smith is such a crappy water heater they figure that they
cant sell to most legit plumbers out there so they
have decided to sell to the un-suspecting public instead
their motto is....................
If you cant make a better product,
find a dumber market to sell it to
onealmr
Reimbursed for what? The lawsuit was for a non-monetary gain. It was a lawsuit because the T/couple kept breaking. It kept breaking because the chamber kept overheating. It kept overheating because civilians would not keep the Flame-trap vent cleaned off. Twice a year is all that should be needed to clean the vent. Civilians were too lazy to do that.
