What's causing the leak?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by despec, Sep 7, 2007.
  1. despec
    despec New Member
    Jul 16, 2007
    Hello to all,
    I have a three-stem shower set-up. When I use the diverter to direct water to the showerhead, I notice that water is leaking from the cold water stem (leaking through the escutcheon and traveling down the stem). Is there a washer or seat that needs to be replaced, or do I need to replace the whole stem. I have already replaced the diverter stem thinking that that might be causing the leak, but I still have the leak.
    Thanks for all help in advance.
    Regards,
    David
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Tighten the packing on the stem....the nut that threaded tube allows the scussions to thread tight to the wall before the handle.
  4. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    I would take off the handle and chrome to find the packing nut behind. Then tighten the packing nut that the stem pokes through and check for any other signs of trouble.
    The best thing to do is replace the whole unit to a nice new single handle valve, and not throw money at something that is old and worn.
  5. confutatis
    confutatis New Member
    Sep 11, 2005
    Patrick,
    I definitely would like to go to a single handle unit and such, but that would mean a lot more work, and work that I am not confident that I have the expertise to do. Quite honestly, I'm really tired of dealing with these stems!
    David
  6. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    If you have a supply house that caries all the parts you need just replace all the internal pieces, Seats, Stems, Bonnets, and packing nuts. Just think if the valve lasted this long before it started to leak replacing all the parts should make it last for a long time.
    I don't see the point of doing minor repairs like tighten packing nuts because they are a temp fix at best and if you turn them to much they can break. The packing in the old valves are rubber and when the rubber gets old it cracks.
  7. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    If the packing nut doesn't work, the valve is likely either a Gerber or a General.
    Supply house should have those parts.
Similar Threads: What's causing
Plumbing Forum, Professional & DIY Advice Help! Not sure what's causing this Jan 8, 2014
Plumbing Forum, Professional & DIY Advice What's in a glass of water? Saturday at 10:38 AM
Plumbing Forum, Professional & DIY Advice Slab leak? If so, what's next? Jan 11, 2017
Plumbing Forum, Professional & DIY Advice What's the difference between these two overhead sewer setups Dec 7, 2016
Plumbing Forum, Professional & DIY Advice What's under my 1957 Floor boards !!! Jan 12, 2016
