what tool do you use to clean smaller pipes?
Discussion in 'Drain Cleaning' started by Pipe7000, Oct 13, 2009.
  1. Pipe7000
    Pipe7000 New Member
    Oct 13, 2009
    ottawa Canada
    hi,
    i was wondering what the preferred tool would be to clean smaller lines such as sinks, bathtubs etc. I know there are handheld tools like the super Vee, as well as units that sit on the floor with a guide hose, like the Rigid K40. What are the pros and cons of either tool? which do you prefer and why?
    thanks
  2. Jay Mpls
    Jay Mpls Master plumber
    Sep 29, 2008
    Master Plumber /Sewer rat
    Minneapolis
    Great big fan of the Ridgid K39af. No problem getting through traps and has a feeder.
    So even doing an overhead tub line is a neater easier job!
  4. hj
    snake
    For those I use my Rigid cordless unit, which they decided to discontinue and stop making batteries for it. Which means someday it will become "useless".
  5. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    I have a cheap little Ridgid Auto-spin that works pretty good for what it is. The clutch system is plastic though so I'm just waiting for it to break heh.
  6. jonebell
    jonebell New Member
    Dec 30, 2009
    US
    Hey,
    You can scrape your resin with a sharp knife or even tweezers. When you've scraped your resin, soak the pipe in isopropyl alcohol until it's clean. You may have to rub it mid-way through the soak with a paper towel or brush.
    Thanks.
  7. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Ummm I think perhaps we might be talking about a different type of pipe cleaning...
    Maybe you got lost on the way to the High Times Forums....:rolleyes:
    And Hi there Spammer Marcy Tate...
  8. Plumbermurrieta
    Plumbermurrieta Plumber
    Feb 21, 2010
    Murrieta Southern California
    -Rigid pipe, usually installed in new homes, makes a neater installation, but it is much more difficult to install than soft, flexible copper pipe.
    -Flexible copper pipe is best for repair work since it can be run around obstacles without connections or cuts.
    -Copper pipe is available in three basic types: Type M is thin-walled, Type L is medium-walled and Type K is thick-walled. In most cases, Type L is good for home use.
  9. hj
    Murietta. None of that applies to the original question regarding cleaning small drain lines.
Similar Threads: tool clean
Drain Cleaning Which plumbing tool do I use to unclog a outside drain Jun 5, 2013
Drain Cleaning The worlds best sewer tools and equipment ! Jul 18, 2010
Drain Cleaning Two Droplets of drain cleaner Feb 18, 2017
Drain Cleaning Plumbing story of the day: Drain Cleaners Nov 1, 2016
Drain Cleaning Questions to ask a drain cleaning company - regarding old pipes Dec 30, 2015
