What "O" ring for a Leaking Honeywell Zone Control Valve V8043l
Discussion in 'Boiler Forum' started by ap, Apr 28, 2012.
  1. ap
    ap DIY Junior Member
    Feb 17, 2010
    Canada
    Was hoping someone knows the size/type of "O" ring I need to get to correct a leaking zone valve ... I can see water escaping from the edges of the square cover plate that is held on with 4 screws ... so far the motor seems unaffected and no water damage (lucky) ... also I can remove the motor and I see no water leaking from the ball shaft. I presume a new O ring will correct the edge leak but other than on line I cant source one locally cause I don't know what size etc I am dealing with. If anyone happens to know that would be great - would like to try to find one locally today if possible... local suppliers are happy to provide the entire Valve for $100. but I figure a .75 cent O ring should do the trick. Thanks
Similar Threads: ring Leaking
Boiler Forum Boiler firing without call for heat on cold start Sunday at 6:17 PM
Boiler Forum Triangle tube boiler, ignoring demands for space heating Feb 9, 2017
Boiler Forum Boiler stopped firing overnight without indication of error Feb 2, 2017
Boiler Forum hydronic question on wiring a zone valve to shut off qravity feed to upstairs loop Jan 7, 2017
Boiler Forum Wiring for Weil Mclain CGA 6 Aug 14, 2016
