What is this and what does it do for my NG furnace?
Discussion in 'HVAC Heating & Cooling' started by greaper, Apr 14, 2013.
  1. greaper
    greaper New Member
    Apr 14, 2013
    Richmond, VA
    I have a rental house and the other day my tenant called to tell me that there was no heat or AC. After further investigation I found that I had a bad EZ-TRAP float switch. I also noticed that there was a pair of wires just hanging that I thought was connected to this device that is on the exhaust flue. Can someone tell me what these pictures are of and what is it used for? I am also not sure if there is supposed to be two wires going to the small device in front or just one?
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    It is a barometric damper and a thermostatic switch that has been defeated.
  4. greaper
    greaper New Member
    Apr 14, 2013
    Richmond, VA
    Thank you for the quick answer. Two questions. What is a barometric damper? How is the thermostatic switch supposed to wired? I assume that if the temperate rises to high at the switch that it is supposed to cut off the unit?
  5. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    I'm not a HVAC tech so I cannot cite code, but that thermostatic switch does not look like a code compliant setup. I think it was probably something that a well meaning DIY'er jury rigged. My guess is it was meant to detect a flue reversal (downdraft). I would use a CO detector to monitor for flue reversal.
    The barometric damper regulates the amount of draft by mixing in cooler room air whenever the draft is too strong.
  6. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    It is a 180 degree Presidential solution. And it does not belong there.
  7. greaper
    greaper New Member
    Apr 14, 2013
    Richmond, VA
    Again, thank you for the replies. I guess based on that I will remove it and not worry about it.
  8. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Did you find the original problem with it ? Why it was not working.
  9. greaper
    greaper New Member
    Apr 14, 2013
    Richmond, VA
    Yep, it was the EZ-TRAP float.
  10. Failure2Comply
    Failure2Comply New Member
    Sep 3, 2012
    Commercial HVAC
    Virginia, USA
    Someone installed an warp disc limit (180F "Flue Draft Spillage") switch on your barometric relief damper. They must have had a venting issue and band-aided the problem.
Similar Threads: does furnace
HVAC Heating & Cooling Gas Furnace Blower motor does not always cycle Oct 22, 2015
HVAC Heating & Cooling What does Design Loss means when choosing a furnace? Dec 31, 2014
HVAC Heating & Cooling Electric furnace blower motor doesn't turn on once in a while Mar 7, 2014
HVAC Heating & Cooling Why does my forced hot air furnace not heat above 60 degrees? Feb 11, 2012
HVAC Heating & Cooling Furnace blower does not turn on in the auto position Oct 28, 2010
