what is a vacuum relief valve for?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by northman, May 14, 2007.
  1. northman
    northman Member
    May 14, 2007
    Washington
    on a water heater/expansion tank installation?
    Looking at the Watts site to size an expansion tank, they show a vacuum relief valve installed at the water heater. What is the purpose? Is it necessary or are they just trying to sell parts?
    Greg
  2. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    "Vacuum Relief Valves are used in water heater/tank applications to automatically allow air to enter into the piping system to prevent vacuum conditions that could siphon the water from the system and damage water heater/tank equipment." and no you don't need it.
  4. jadnashua
    My city requires them on new installs along with a tempering valve. My guess is to prevent what may be heated water that has sat for awhile in the water heater from being sucked back into the rest of the potable water. Since all of the water is supposed to be potable, not sure why, but as I said, it is code in my city.
  5. hj
    vacuum vent
    If the heater is in an upper floor level or attic, then the negative pressure created by a broken pipe draining the heater could collapse the walls of the heater. In this case, the installation requires a vacuum vent to relieve the negative pressure. It is not required if the heater is in a basement or first floor because those installations cannot create high negative pressures.
  6. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Required on most commercial applications regarding restaurants, nail shops, beauty salons, where chemicals/cross connections are possible above mild.
  7. hj
    valve
    Those applications do not require a vacuum relief valve, they require backflow prevention devices, and the higher the possible contamination level, the more sophisiticated the device has to be.
Similar Threads: vacuum relief
Plumbing Forum, Professional & DIY Advice vacuum relief valve? Sep 5, 2008
Plumbing Forum, Professional & DIY Advice Vacuum Breaker Help May 30, 2016
Plumbing Forum, Professional & DIY Advice Proper place for vacuum breaker Sep 12, 2015
Plumbing Forum, Professional & DIY Advice Is this an older style frostfree faucet vacuum breaker? Aug 11, 2015
Plumbing Forum, Professional & DIY Advice Is a vacuum breaker suppose to leak? May 15, 2015
