Wet Vent Drain Sink Into Toilet 3" Vent or Add Elbows to a Vent
Discussion in 'Remodel Forum & Blog' started by remodel4ever, Apr 15, 2013.
  1. remodel4ever
    remodel4ever New Member
    Apr 15, 2013
    Austin, TX
    This is a remodel of a 2nd floor bathroom. Original plumbing is hubbed cast iron and screwed steel. Mods will be made in PVC, with tie-in by screw and/or no-hub compression couplings.
    Looking at the wet wall from left to right I have the 4" iron main stack, existing sink drain, 3" screw pipe vent for downstairs toilet. Vent is commoned back to the main stack at about 4" height.
    The sink drain currently runs laterally into the main stack. The sink drain location is moving to the right of the 3" vent. Should I consider draining the sink into the 3" downstairs toilet vent? Or should I add elbows to the 3" vent and dog-leg it around under the new sink drain location? I understand a wet vent spanning floors would not be to code, probably for good reason. How bad is adding two, or possibly four elbows to bend the 3" toilet vent around the new drain location? Is 4 elbows in the vent ok? It would simplify the cutting and splicing.
  2. hj
    It is probably a 2" steel pipe, because no plumber would work with 3" screwed pipe in a residence. You can offset a vent with as many elbows as necessary, or as many as you want to use.
  4. remodel4ever
    Apr 15, 2013
    Austin, TX
    It is 3" screwed steel pipe in a residence, built in 1963. Along with the 2" screwed pipe. Along with the 4" and 2" hubbed iron pipe. Lots of variety.
    Excellent to hear I can offset the vent with multiple elbows. Thanks much!
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    As long as the bends in the vent will not trap any incoming rainwater or condensation, you are golden.
Similar Threads: Vent Drain
Remodel Forum & Blog Drain into vent? Jul 30, 2016
Remodel Forum & Blog Draining/Venting Tips Needed Aug 20, 2012
Remodel Forum & Blog Shower drain re-venting question Jan 29, 2012
Remodel Forum & Blog Drain and Vent question in small bathroom Dec 13, 2011
Remodel Forum & Blog need help with bathroom sink and bath tub drain and vent May 8, 2010
