I have purchased a house that had an exsisting well and am trying to figure out the flow rate of the well. Not the flow rate of the pump but the actual flow rate of the supply to the well. I have the original Well construction report when the well was drilled, but there is a value on there that I do not know what it means? It says the yeild = 400 gallons per N. Can I figure out how many GPM the well produces?
I am trying to figure out if the well would be able to support another house (2 total). The rest of the specs are
Total Depth of Well: 160 Ft
Statis Water Level: 90 Ft. below land surface
Diameter of Bore Hole: 6.00 IN.
