Weird mounting type on kitchen sink
deerater
Texas
Pic of one of the four mounting brackets on the underside of this drop-in kitchen sink. Bought it from a surplus store so it came with nothing. I can't even find pictures online that look like this so I can find the clips or whatever is necessary to attach this sink to the countertop. Can anyone tell me what I have here or what kind of clips to get?
Many, many thank yous in advance.
Is that photo looking under the rim, or is it looking at the outside of a bowl?
If its a hard countertop like granit or quartz I seen them just put a wooden clamp with screws (short ) into the rough top. other wise make your own clamps
deerater
Texas
it is a no-name pos. but, try Elkay clips, they might drop in and work.
I swear I've looked at Elkay and other brands. I don't see any that will clip on or insert into the brackets on the sink. I think I'm looking for a unicorn.
honestly for my time I wont even look. but I wouldnt discourage you from scouring sources are you useing a hootie ring with the sink?
Breplum
Licensed plumbing contractor
San Francisco Bay Area
oops spelled it wrong , how is this sink going in no srainless steel ring around it? ring comes with clips .
just need something to pull down slightly and caulk it in easy as pie ! shouldnt be any problem
deerater
Texas
Update. Bought the Elkay clips. The mushroom is too big for the hole. Do I... drill it out and make it fit? If no clips, would siliconized sealant do? Put a 5-gallon bucket of water in the sink to weigh it down?
Many thanks for the input!
Im not seeing how those will work . It might caulk in ok without clips . set the sink in the hole as a test fit , if its sitting all the way down then you dont need the clips but if I remember correctly the corners of the sink curve down a tiny bit and you need to pull the sink down a bit with some kind of hold down for better results im not 100 perce3nt on the sink having a curve to it.
deerater
Texas
I actually found a place online that has the H clips in stock. Costs me $13 shipping, but seems that's what I need to do if I want the sink securely fastened to the countertop.
It sits fairly flat, but could certainly be better.
Lesson learned. This "good deal" is not so good after all.
We were wanting to see a photo from below showing a clip in action.
