WAX or No wax...that is the ?
Maemer
I want to ask the professionals...I'm going to install my own TOTO Soiree...should I use a wax ring or the Waxfree Toilet Seal...right now, mine is on wax...but it need your wise council.
Thanks
Either will work. With the UniFit adapter, it's less money, and actually easier to just use a wax seal. The big advantage of a waxless is if the toilet flange is not exactly where it should be (i.e., maybe too low, at least based on 'normal'). The other big advantage of a waxless is if you're removing a conventional toilet to say paint behind it...but, with the Unifit adapter, you don't need a new wax ring since that stays in place when you lift the toilet.
