HK33
Hello,
I recently moved into a home with a water softener+water filter tank and we're having issues with hard water stains and mineral build up.
The water is piped to go through the Culligan Medallist automatic water filter tank first then into a Hydrotech 5600XT water softener system. Both are connected to the same drain and only the 5600XT is connected to the brine tank. Below is some of the basic troubleshooting I've done but still no change:
*disconnected brine tank, removed all salt and thoroughly cleaned tank - about 2/3 was normal looking salt chunks and 1/3 of it wasn't dissolved, looked like sand and was slightly dirty (sat at the bottom of the tank)
*removed float valve assembly - rinsed it under tap water to remove the sand like salt it was sitting in and confirmed the float valve would move when I tipped it up side down and right side up before putting it back into the brine tank
*checked the nozzle and filter/screen on the 5600XT and they were mint, no clogs or mineral build up
*put everything back together, filled the brine tank about 2/3 full with salt, added water - watched it go through a cycle and can confirm the water from the brine tank to the water softener is moving freely. I also pumped out a bit of water out of the brine tank to see if the valve float control was working correctly on the next cycle and it did. Let it go through a few more cycles - tested my kitchen tap water with a TDS/PPM meter and I'm getting over 400ppm (lol). My RO water is 6 or 7ppm. Two months on, the system has barely used any salt, about 1" less than when I topped it off, seems odd to me.
Any response is greatly appreciated, I'm trying to a void having a tech come in for my family's safety during this COVID circus. Stay safe everyone.
