rural_engineer
Here's my planned water treatment setup for my well:
Pressure Tank (50 /70 psi)
Hydra 90 micron sediment filter
64,000 grain Fleck 5810XTR2 water softener (Iron Out in the brine tank)
20" Pentek Big Blue filter with 50/5 micron dual gradient cartridge
(Optional addition if needed: UV sanitizer.)
APEC RO-PERM upgraded to 3/8" tubing with a 20 gallon tank, feeding drinking/cooking water taps in the kitchen and bathrooms
Does this make sense? Would you make any changes?
Here are the results of the water test:
pH 7.41
Total Dissolved Solids PPM 603.6
Turbidity NTU 2.01
Conductivity umhos 1006
Color CU 15
Hardness (Ca,Mg) PPM 426.8
Hardness (Total) PPM 431.99
Grains per gallon Grains 25.46
Alkalinity (as CaCO3) PPM 330
Langelier Saturation Index 0.48
Sodium Adsorpsion Ratio 4.88
Total THMs PPM 0
Here are the analytes that were detected in the water:
Aluminum PPM 0.01
Barium PPM 0.07
Boron PPM 0.04
Calcium PPM 104.77
Chloride PPM 68.45
Copper PPM 0.02
Fluoride PPM 0.63
Iron PPM 0.56
Magnesium PPM 40.11
Manganese PPM 0.04
Nitrate (as N) PPM 1.55
Potassium PPM 2.22
Silica PPM 7.83
Sodium PPM 41.52
Strontium PPM 3.15
Sulfate PPM 46.69
Uranium PPM 0.001
Zinc PPM 0.27
pH 7.41
Turbidity NTU 2.01
Color CU 15
Total THMs PPM 0
Aluminum PPM 0.01
Barium PPM 0.07
Boron PPM 0.04
Calcium PPM 104.77
Chloride PPM 68.45
Copper PPM 0.02
Fluoride PPM 0.63
Iron PPM 0.56
Magnesium PPM 40.11
Manganese PPM 0.04
Potassium PPM 2.22
Silica PPM 7.83
Sodium PPM 41.52
Strontium PPM 3.15
Sulfate PPM 46.69
Uranium PPM 0.001
Zinc PPM 0.27
