Water temp
Discussion in 'Water Heater Forum, Tanks' started by karter56, Mar 7, 2013.
  1. karter56
    karter56 New Member
    Feb 19, 2013
    Charlotte, NC
    I recently replaced the water heater that runs to the water coil on my hydronic furnace. Can anyone tell me what temperature these systems typically run at? The old system had no gauge on it at all. I'm currently running it at around 140 degrees.
  2. jadnashua
    140 is a common number...anything over 120 (and in some places it doesn't matter, you) need a tempering valve to limit it to 120-degrees. Having higher storage temperature gives you a greater quantity of hot water since you'll almost always be mixing it with cold, either via the tempering valve or at the point of use. This means you don't need as much hot volume for things like a shower (makes no difference on the quantity of hot used to say fill a tub, though). Mine is set to 140. A higher temp also means things can't grow in the warm water, which is a good thing. A typical indirect WH has great insulation, so there is not a lot of standby loss verses say a gas fired WH.
Similar Threads: Water temp
Water Heater Forum, Tanks Temporarily move a water heater? Jan 19, 2017
Water Heater Forum, Tanks Raising water heater temp uses less water? Feb 15, 2015
Water Heater Forum, Tanks Triangle Tube Smart 40 Indirect Water Heater inconsistent temps Nov 16, 2014
Water Heater Forum, Tanks Proper temperature of boiler water going into Super Stor Oct 8, 2014
Water Heater Forum, Tanks Water heater size with and without tempering valve Jul 12, 2014
