Bannerman
@MaplesonD: A mediaguard contains a small amount of KDF so its lifespan and effectiveness will be limited and dependant on the flow rate, the amount of contaminants in the water and how well and how often it is backwashed.
A mediaguard is often used in a backwashing carbon filter to extend the life of the carbon and to prevent bacterial growth as carbon can support bacteria if not fully backwashed with a chlorinated (or other anti-bacterial agent) supply. Carbon is a very good filter media and is effective in reducing/removing many contaminants beyond KDF so a mediaguard can reduce some load off of the carbon especially when the water contains many contaminants.
Since KDF is so heavy, a softener or filter with a mediaguard may require a higher flow rate for backwashing than would be required without a mediaguard. Dittohead and a few others are more knowledgeable on the subject.
A 2 cuft softener does usually utilze a 12" X 52" tank. As no gravel is specified, same advice as indicated in paragraph 2 of post #19.
Answers to your other questions were also provided in post #19.
