Water Softener System
Kevin Murphy
Florida
This is my first well.. It's has as softener tank and a sulfur blocker tank. The water has been smelling like sulfur. I paid someone to come out and they found the softener was working but the sulfur tank was programmed wrong, basically acting as another softener. I know nothing about this and want to make sure it is set up correct. Can anyone tell me the correct settings? So he just set it up to regen the sulfur tank daily at 12AM, and the softener every 7 days at 2AM.
To understand what is needed for a sulfur blocking tank, it would be good to know what the media is. And if a solution gets drawn in during regeneration. If the system was intended to draw in a bleach solution, and you stopped providing the bleach solution, that would hurt the performance.
Sanitizing your well and plumbing can often cut down on H2S (sulfur) smell. https://terrylove.com/forums/index....izing-extra-attention-to-4-inch-casing.65845/ is my writeup for sanitizing with submersible pump wells. If your pump is above ground, then that write-up will not be so applicable.
With regen at midnight, I presume you told him that you were earlybirds.
