Water softener salt and water level
Discussion in 'Water Softener Forum, Questions and Answers' started by boerdoc, Jun 5, 2009.
  1. boerdoc
    boerdoc Member
    Jul 13, 2008
    Idaho
    Just a quick one. How high should the salt level and the water level be? maximum. My salt tank is 18-24 inches square ands about 48 in. high. When the salt gets low I can reach my hand down and feel that the water is about 12 inches deep. Just curious if this is normal. I guess I could get out a manual but you are all so informative. Thank you
    Kent
  2. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    Not sure what about your situation, but as a general rule the water should be about 1" above the tray on the bottom of the brine tank before the salt is added.
  4. Gary Slusser
    Retired
    The volume of water in the salt tank depends on your salt dose lbs. and that varies with different size softeners but more so the amount of hardness etc. in your water and what type of resin is used and how much water is to be used between regenerations.
    So no one can tell you without much more info.
    And you control the volume of salt you put in the tank, which should not be up to the rim of the tank; a 1/3 to 1/2 full is best and check it more frequently.
    Not all softeners have a salt grid/platform in the salt tank and that 1" mentioned, it may not be appropriate to your softener because you may have Pre brining or no grid or a higher salt dose that would cause the water to be much higher or lower than the 1" above the grid.
    Do you think there is something wrong with the softener's operation?
    BTW, the volume/height of water in the salt tank is not going to be in any manual anywhere.
  5. boerdoc
    boerdoc Member
    Jul 13, 2008
    Idaho
    Nothing is wrong with the softener operation. It works great. Thanks Gary. Just like checking the oil in the car. I want to properly maintain my softener. "An ounce of prevention is worth a pound of cure" as they say. Since this is my first softener I thought I would ask. Thank you all for the help.
    Kent
Similar Threads: Water softener
Water Softener Forum, Questions and Answers Advice for replacing a water softener for iron removal Feb 19, 2017
Water Softener Forum, Questions and Answers I need a professional’s guidance in replacing my water softener. Feb 13, 2017
Water Softener Forum, Questions and Answers Water softener size Feb 9, 2017
Water Softener Forum, Questions and Answers Water Softener & Whole House Filtration Feb 8, 2017
Water Softener Forum, Questions and Answers Is my watersoftener broken? Jan 29, 2017
