Water Softener Issues
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dunkinidaho, Jun 13, 2013.
  1. dunkinidaho
    dunkinidaho New Member
    Aug 6, 2009
    Michigan, USA
    Today I have a question regarding my water softener. I'm not sure I have it set correctly. It is a 40,000 gr. single stage design with 4 stages of cycling. The issue I have surrounds the time I have each stage set for. I have tried for a few years to find information on this on the net without success. It seems the industry has a muffle on the subject. There are only two people in my home and we don't drink the water as we have an RO system. We are on a well. We use K-Lite not salt. I have 1000gals set between cycles. The unit is a Fleck 5600se single backwash. Other settings are:
    Iron 340000 units
    Backwash 16mins.
    Brine Rinse 16mins
    Rapid Rinse 18mins
    Brine Refill 11mins
    Any assistance with this would be helpful
    Thanks
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Without knowing how much hardness and or iron you are trying to remove I can't tell you whether or not its set right
  4. dunkinidaho
    Aug 6, 2009
    Michigan, USA
    Thanks for the response, I'll read you the analysis off the paper:
    results units DL method reference
    hardness by calculation 340000 ug/L 5000 EPA 200.8 rev 5.4
    Manganese not detected
    Does this help
    Brian
Similar Threads: Water Softener
Plumbing Forum, Professional & DIY Advice Low Volume Water Softener (8 gal./week) Jan 18, 2017
Plumbing Forum, Professional & DIY Advice Water Softener Recharge Drain Dec 28, 2016
Plumbing Forum, Professional & DIY Advice No drain near water softener Dec 27, 2016
Plumbing Forum, Professional & DIY Advice Do it Yourself Installtion Watts Water Softener Nov 26, 2016
Plumbing Forum, Professional & DIY Advice Drop in water pressure after new softener put in Nov 3, 2016
