Water softener draining
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Pedelty, Dec 25, 2008.
  1. Pedelty
    Pedelty New Member
    Dec 23, 2008
    I was wondering if you could give me some advice on the best place to have my water softener drain. I have a septic system and I do not know if it is best for the water to drain directly into the septic system or to drain into the sump pump. I also live on a lake. Thank you!
  2. Gary Slusser
    Retired
    The EPA says there is no problem putting the discharge into a normally operating septic system. They also say the 'extra' water is actually helpful. Millions of softener are connected to the septic system but, there are 3-4 states that still ban it. Those states say to use a dry well. And I think your mention of living by a lake goes to polluting the lake which I would be concerned about or polluting your well if you used a dry well or a sump pump.
    I say it should go into the septic.
  4. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    I would first find out where the sump pump is discharging it's water.
    bob...
  5. Pedelty
    Pedelty New Member
    Dec 23, 2008
    Thank you. That was all very helpful
Similar Threads: Water softener
Pumps and Tanks Well Forum & Blog. Water is life. Water Softener Sizing (Flow Rate) Feb 2, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Need Advice, water softener Jun 29, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Need help with building a water softener system Apr 25, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Can I add a booster pump after a water softener? Dec 30, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Question for installing sediment filter and water softener. Sep 3, 2011
