So the drain for my upcoming fleck 5600sxt softener (1.5cu ft) and carbon filter (1.5 cu ft backwashing) isn't in the most convenient of locations. I could run it across the floor 10 feet but it's kind of in the middle of everything and don't want to risk stepping on it/kicking it.
I was thinking of doing the following. Upgrade from 1/2" I/D poly to a 3/4" I/D poly from the tank to the ceiling (ceilings are 8' so ~3.5-4' of rise). Have a barb to threaded PVC adapter, run 3/4" CPVC along the ceiling 10' then 90 it down to the drain. I'd run a similar setup with the carbon filter for it's drain line. Would that work? I was thinking poly for the run to the ceiling so I have a little adjustment room for the tanks.
