watersoftenerrookie
I was thinking the 6 gpm was more likely the well test recovery where drawdown is observed over a few hours.
The 20 gpm could be a lot of different things. It could be the water brought up at 0 psi surface. Well people often do this handy test after installing a pump. It could be the nominal number from the pump at 0 ft of head (likely with inferior well pumps), or could be the gpm rating on the pump at the most efficient pumping (normal well pumps). Knowing the pump make and model, depth to water, and maybe the depth the pump is mounted at and the well diameter would be best for analyzing your options.
To measure the gpm yourself, run water from at least two high-flow faucets (tub and hose bib for example) simultaneously, and measure the gpm by timing the time to fill 5 gallon buckets. And also check that while these simultaneous flows have been happening for maybe 10 minutes, what the water pressure at the pressure tank is. This is not an official methodology. I am not a pro. The point is to figure out how much backflow rate is available for maybe a 10 minute backwash while the pressure stays at at least 30 psi.
If the well can only maintain the required flow for a couple minutes due to running short of water, it is possible to get a controller that can do a series of 2 minute backwashes with a well recovery period between.
I've attached what the state well report says.
The 6 gpm came from the well inspection prior to the home sale in which a well company came in and ran the water for 50 minutes and ran 300 gallons. At least that's what the report says.
