Water Sensor
Discussion in 'Water Heater Forum, Tanks' started by vman, Jun 16, 2009.
  1. vman
    vman New Member
    Jan 6, 2008
    Massachusetts
    Not sure what forum this would fall in. But does anyone use or recommend any "water sensor" that alerts you if your basement starts to flood or major collection of water?
  2. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    There are probably kits to build these. And plenty of circuits for this on
    http://www.electro-tech-online.com/
    In principle you could hook one up to shut off your main water supply if water is detected but an electrically-operated shut off valve costs a half a kilobuck or so.
  4. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
  5. Ian Gills
    Jul 24, 2007
    USA
    For the cheapest option that does not give false alarms and leave your wife clueless as how to turn the water back on, I use one of these.
    [​IMG]
    The simplest solution is often the best one.
  6. chris8796
    chris8796 New Member
    Jan 8, 2005
    Illinois
    I use the watercop system to stop plumbing leaks. Its expensive, but I like all the functionality. It's nice to have a switch at the top of the basement stairs to turn off all water, It also can connect to other security or control systems. I got mine after moving the laundry to the second floor and finishing the basement. The convincing thing was when my daughter propped a glass in the frig water dispenser and forgot it, then went to school for 8 hrs. Around the same time, I had a friend have a PRV fail and have 125 psi break a plastic part in the water softner and ruin his basement.
Similar Threads: Water Sensor
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Tuesday at 3:50 PM
Water Heater Forum, Tanks Water heating Monday at 7:57 PM
Water Heater Forum, Tanks My T&P valve is expelling 1 cup of water per day Monday at 11:17 AM
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Feb 15, 2017
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
