water pressure on a cistern pump
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by osterhj, Apr 20, 2007.
  1. osterhj
    osterhj New Member
    Apr 20, 2007
    Here is my problem. When my pump cycles on I temporarily loose all pressure for a second or two. Not short cylcling. Last week the pump must have sucked up some sand or grit from the roof. because my cold water inlet on my washing machine clogged up and I had to clean the airators on most of the faucets.
    I dont have any filtration. I dont see a way to clean out the pressure tank.
    Any ideas?
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Two things. First if you have a bladder tank, the air pressure may be set higher than the on setting of the pressure switch.
    Second, if you can see the dirt in the tank and the tank is higher than the ground, you can use a hose, get a syphon going and use it as a vacuum cleaner on the bottom to suck the debris out. It always works on my hot tub.
    bob...
Similar Threads: water pressure
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure fluctuates Feb 19, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Low water pressure on well system Jan 17, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Newbie help with water pressure issues, thinking of a CSV Jan 3, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure trouble shooting Nov 12, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Complete redo of water plant - replace pressure tank with CSV Oct 17, 2016
