Water on bathroom floor.
rugoofy
Rockford, IL
After taking a shower my bathroom floor is dry but when I go back in there 1-2 hours later there are puddles of water on the floor. Any suggestions as to what could cause this? This only happens after taking a shower. Any suggestions are appreciated! Thank you!
leaky shower pan a likely cause, you could try dumping water down shower drain from another source garden hose etc and see if water pools up.
wter could leak through the drainage system or be leaking from the valve or shower head inside wall and eventually leak out onto floor so investigate further and then get back good luck
