Water Meter Couplings
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by JasonG, Sep 15, 2007.
  1. JasonG
    JasonG New Member
    Aug 28, 2007
    Is it normal to have 3/4" galvanized main supply line, to 1/2" brass water meter coupling, to 5/8" water meter, to 1/2" brass mater meter coupling, to 3/4" galvanized supply line?
    Why is it reduced down to the 1/2" couplings?
    Are there 3/4" coupling that I should use?
    Thanks,
    Jason
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    it's not uncommon to have a supply line larger than the meter, but I see no point in the 1/2" portion. The larger supply line is to cut down on friction loss. I would be concerned about the galvanized supply line. It surely is quite old as galvanized pipe has not been used for many years.
  4. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    You got 1/2" couplings because someone wanted to save $2 when they installed the meter. The couplings are usually the responsibility of the utility that installs the meter.
    The couplings may be what they got when they bought a bunch of meters from the lowest bidder.
    The change in size going in and out of the meter will cause more pressure loss at high flows. The proper way to do it would be to install a 3/4" coupling on the pipe, and a 3/4" meter coupling on the meter, but it may not be worth it if you aren't having pressure problems.
Similar Threads: Water Meter
Plumbing Forum, Professional & DIY Advice Am I being SCAMED? Can water PSI be read by a 266 Clamp Meter?? Nov 28, 2016
Plumbing Forum, Professional & DIY Advice Diameter of 300' Waterline Nov 3, 2016
Plumbing Forum, Professional & DIY Advice How to winterize water meter in open pit and street-side pipes Oct 28, 2016
Plumbing Forum, Professional & DIY Advice New construction main waterline size 900' from meter Oct 3, 2016
Plumbing Forum, Professional & DIY Advice Water meter washer replacement DIY questions Sep 5, 2016
