Water in the drain tube
Discussion in 'Water Softener Forum, Questions and Answers' started by rkhanso, Jun 8, 2013.
  1. rkhanso
    rkhanso Member
    Feb 18, 2010
    MN
    I have a greensand filter and just noticed that there is water in the drain tube. I've seen this a few times over the last 2weeks when I've checked...but can't say for sure it happens all the time. The entire hose length is filled with water. This is the drain hose from the filter, not the Potassium tank.
    Not sure when the filter ran the last time. If I wiggle the hose and lift the end up/down the water will eventually drain out when I get enough air bubbles up there to replace the water and it trickles out.
    I checked the end of the hose and it is NOT below the water level in the floor drain. There's at least a 2-3" air gap between the bottom of the drain hose and the water in the floor drain. There is a slight bend near the end of the hose where it gets inserted through holes in the plastic floor drain cover. Over the past 3 years, I haven't seen it do this before....so it's a fairly new thing to happen.
    Should I be concerned? I'm hoping it just gets blasted out when the filter runs.
  2. ditttohead
    Jan 9, 2012
    Ontario California
    Sounds normal to me.
Similar Threads: Water drain
Water Softener Forum, Questions and Answers Can a water softener and backwash sediment filter share same drain tube? Jan 17, 2017
Water Softener Forum, Questions and Answers Drain Size for Backwash Filter and Water Softener Aug 21, 2016
Water Softener Forum, Questions and Answers Water softener drain line tied directly into sewer line Aug 7, 2016
Water Softener Forum, Questions and Answers Water Softener Drain - Do we need a Vent for a Floor Drain or ? Jun 19, 2016
Water Softener Forum, Questions and Answers Proper Drainage Of My Water Softener Apr 29, 2016
