Water heaters piped in parallel
GreekGuy7
Illinois
I have 2 50gallon hot water heaters piped in parallel for a 6unit apartment building. A few days before Christmas I replaced one of them because it was leaking, but not the other. (mistake number 1). The new hot water heater is now several inches higher than the older one.
Doing some "pipe-grabbing" while a hot faucet is on, it looks like the new one is being used a little more than the old one although both are running. I tried closing the ball valve on the output of the new one just a little to create some restriction so I can balance the two water heaters out. Any drawbacks to this??
I do plan on replacing the older one as soon as I get a chance.
aphco
Master Plumber,Mech Contractor
Michigan
Check it out!
Just found this forum and just joined.
Greek Guy7, do some research before you replace your heater. Every heater manufacturer that I know of advises that the best set-up is a parallel installation.
We have always installed heaters in parallel and have never had a problem. We have also changed installs from series TO parallel and it always cures the problems. Also when installing more than 2 heaters they are done in parrallel.
Series is not as efficient and does not allow shutting off one heater at a time if there is an outage or a leaker. With series you might as well have only one heater because when one goes out they both have to be shut down.
The important thing is to remember to balance the piping so that the resistance is the same for each heater and the draw is equalized.
Master Plumber Mark
www.weilhammerplumbing.com
series simply works best
this last guy stated at the end of his post....
The important thing is to remember to balance the piping so that the resistance is the same for each heater and the draw is equalized.[/quote]
gee...is that all I got to do??
The problem is over time the heaters start to corrode
at the inlets and clog up through the dialectric unions..........
and you get more draw from one than the other...
if your parrell piping is of just a half an inch off from perfect,
you will get more draw from one over the other....
then when one water heater goes out....you MUST replace it with
the EXACT same heater 10 years from now or your draw
will not be exactly the same between them....
like the problem this fellow faces right now....
he just cant replace a heater plumbed in parrell..with just any
heater off t he street...and expect it draw
right......
been there ...done that ....and got the tee shirt too.....
Jluksic
Colorado
In support of Series...
Dubldare's pdf link implies that both parallel water heaters are set to equal temperatures - which causes the first WH to wear faster. I think most WHs in Series are configured to step the temperature, the first raising the temp to ~75F and the second to final temp ~ 140F.
aphco
Michigan
1) I'm new to this forum, but not to plumbing and I hate to disagree, but,I suggest that you check the water heater manufacturers' websites and see if any advise the use of a series installation. If so please post a link.
2) Setting a water heater to only 75 degrees ( if the thermostat will even go that low) will set up a heck of a condensation problem and rot out a heater way before its time.
3) It is not an exact science, but you can match the piping lengths on the original install and in the future use a water heater that comes as close as possible to the old heater.
4) Especially in multi-family dwellings the parallel installation gives you the ability to have one heater out of service and still use the other until the bad one is replaced. Try that with a series install.
5)If dielectric unions are plugging up, don't use them. Use a brass union and a brass nipple to keep the water way clear. Even though dielectric unions are approved they cause more trouble than they prevent.
6)Explain to me how you successfully hook up 3 water heaters in series and provide fpr individual shut offs. Easy to do in parallel.
Kordts
exurban Chicago
I can explain how I pipe in series and can shut down one of the heaters. You pipe a bypass with 5 valves and you're good to go.
Master Plumber Mark
by-passing on series
like the Mr Kords fellow said,,,
its just a matter of simply putting a by-pass across
the top of each water heater each water heater
will ball valves.... just like a water conditioner.....
on two heaters you would need 6 ball valves...
3 for each heater......one horizontal across and two verticle in and out
and maybe an extra one
before it comes to the heaters if you wish....
nothing has to be "exactly the same in length"
you CAN replace one heater years later with any brand you want
and you dont have to worry about draw.......
so what makes this----- brain surgery????
as far as setting the temps, I think the first heater
should be set about 110 and the second one to be
set at 125+
ans you will have a continous feed of 100 gallons
you really cant go wrong..
mike08201
Absecon, NJ
www.neavear.net
master plumber mark said:
you would be best to just change itto series and
forget about it......
series works best in about every situation...
you absolutley KNOW that it will give you 100 gallons of
water no matter which heater begins to clog up first....
In total agreement on that! I'm just a rookie but I can speak from first hand knowledge on this issue.
When I had my old oil fired boiler it had the coil for hot water, never quite did the trick to my satisfaction. So I bought an electric 40 gallon and had the boiler feed it with pre-heated water and the electric took it the rest of the way. (In series)
I NEVER ran out of hot water, it was great. Then we coverted to gas and i lost my hook up <sigh>
I miss the old days LOL
