Water heater-wet spot
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Mike50, Dec 21, 2006.
  1. Mike50
    Mike50 DIY Senior Member
    Jan 8, 2006
    Southern California
    Circular Wet spot directly underneath water heater in garage. (no pan) Seems to have slow leak into corner of bedroom. It's due date is up. Is it shot??
    Just checking the obvious here....
    thanks..
    Mike
  2. Cass
    Cass Plumber
    Nov 12, 2005
    If there are no leaks on the top at the inlet and outlet and at the T&P the only other places are the thermostat and drain cock. If none there then the tank needs to be replaced. Look with a good light to be sure. You need to find a water trail leading to the floor or a drip.
    What brand is it and how old is it?
  4. Mike50
    Jan 8, 2006
    Southern California
    Cass, I checked and there are no leaks from any piping anywhere. The tank is flush with the ground and that is where leak (wet spot) is coming from.
    It's a Reliant 501 5 year tank.
    Was here when I moved in----February of 2001.
    I check it after showering. Maybe it's my imagination but the tank is clearly making
    a whoosh-wave sound. Laboring slightly.
    It IS however next to washer which had some issues a couple years back.
    Mike
  5. Cass
    Cass Plumber
    Nov 12, 2005
    For some reason I was thinking it was a gas heater.
    Did you check the elements for leaks?
  6. Mike50
    Jan 8, 2006
    Southern California
    Cass, I am unable to closely inspect anything--just had a angioplasty thing done.
    My trusted plumber friend is out of town. damn...
    I'm getting it replaced. It's due and water is leaching up the wall...
    What is *price range* for 40 gallon installed iyo. Brands??
    Mike
  7. Cass
    Cass Plumber
    Nov 12, 2005
    I have no idea what the going rates are in your area. Get a couple of prices since the plumber you trust is gone.
  8. Mike50
    Jan 8, 2006
    Southern California
    Thanks Cass. My guy quoted me 450-500 installed. Just called Local Rooter and was quoted 750 installed.
  9. Cass
    Cass Plumber
    Nov 12, 2005
    If you can wait for your regular plumber it looks like he can save you some $$$$$. If not get 2 more prices.
  10. hj
    heater
    Unless you are by yourself, a 40 gallon heater is almost too small these days with the lower temperature recommended for safe use. $500 is closer to the correct price assuming it is not buried behind a water softener or furnace.
  11. Mike50
    Jan 8, 2006
    Southern California
    Thanks..
    This is a small leak. No panic.
    All 3 guys quoted me 750-795 installed.
    I'm waiting for my plumber friend on Tuesday...
    Mike
  12. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    Lately I've been figuring $200 plus cost of materials. Last job I did came to $515 for a 50 gal replacement where a 30 gal was... in a mobile home. The rooter folks are always going to be much higher and give you a much better written warranty.
  13. Mike50
    Jan 8, 2006
    Southern California
    I have an easily accessible electric 40 gallon. No corrision or whatever...
    Thanks to this board--I know when I'm getting hosed.
    Merry Xmas Ho-Ho-Ho
    I guess when you use the "L WORD"-A Surcharge applies.
    The L Word is of course L-E-A-K lol
    Mike
  14. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    If 3 local plumbers quoted you similar numbers, you are not getting hosed. Every area has different prevailing rates. When I install a heater, I use all brass fittings, remove the plastic drain valve and replace it with a fullport ball valve with a hose adapter. Some plumbers or handymen can do it cheaper, but not better.
  15. Mike50
    Jan 8, 2006
    Southern California
    I waited and my guy quoted me 625. No haggling. Very happy with result. Pan-blanket as well.
    Glad I waited. I told him when we met 2 years ago I would send him a very lucrative business/residential account. It paid off in spades with multiple remodels-same family. It's all good...
    M.
  16. vaplumber
    vaplumber Guest
    Sounds like you did good with the pricing in your area. Considering pan/blanket you did well... And you know the man's work who did the job. At that age for that tank, replacing was the best choice. No use wasting money on trying to chase ghosts.
  17. hj
    heater
    The pan is a bonus if it was piped to a drain. The blanket can be a negative. Some heater manufacturers, especially for electric heaters, discourage their use. How much "better" can an RR written guarantee be? The only thing they could guarantee is the water heater and the manufacturer already warrantees that.
  18. 007plumber
    007plumber plumbing contractor
    Dec 27, 2006
    plumbing contractor
    georgia
    007plumber
    a water heater pan is worth its weight in gold! recently a relative of mine who owns a condo that he uses as a second home and rents out called me about replacing the water heater. It was located in an outside storage closet on patio. The inside wall was also the wall to the bedroom. The tank had a decent leak and ran under the shoe plate. It was not noticed until a renter called and said the floor was wet. By now the water had saturated the sub-floor,damaged the floor joist,mildew in the wall and termites for good measure. Items replaced : joist,subfloor,several studs,sheetrock,carpet and re-painted walls. Total price : $12,000 not including new water heater,which I installed for cost. Needless to say we went back with a pan and drain. Local code did not require pan because of location of heater but sometimes it's up to us to go beyond the minimum requirement to avoid such a catastrophe. Pan costs $15.00, brother-in-law for a plumber-PRICELESS!
  19. Randyj
    Nov 25, 2006
    Alabama
    007... I tend to jack them (electric WH) up on blocks above the pan to keep the bottom of the water heater from rusting out. It also gives the rats a better place to hide.
  20. Mike50
    Jan 8, 2006
    Southern California
    That's an important post imo. I in fact already DO have some minor water damage because I previously had No pan. (see earlier post). That's why I insisted on one. I'm having mine hooked to an exterior pipe which will gravity drain down my driveway as I live on a hill in the event of a leak. (It won't be noticable...and behind washer-dryer units.)
    Pans are cheap but price is not an issue in my tiny mind. Hell...I'd pay 200 bucks for one if I had to.
    Think about it--40 gallons of rushing 120 degree hot water can easily be a small Disaster!
    No problem with garage rats--or anything else uninvited for that matter. I have 2 fearless pitbulls.
    Their motto: "Go ahead-make my day" LOL :D
    Mike
  21. Mike50
    Jan 8, 2006
    Southern California
    For some reason I have about a half cup of water in my pan from the new tank. My guy has to come back to reconnect the swamp cooler valve and wrap the blanket-so It's no big deal but I'm curious....
    This is a Bradford White.
    Why is it that you have to decode manuals to figure out how long the tank is guaranteed for..? Im still not sure. It's 6 or 10.
    M.
Similar Threads: Water heater-wet
Plumbing Forum, Professional & DIY Advice Hot and Cold PEX Connections to the Water Heater from Below Yesterday at 7:14 PM
Plumbing Forum, Professional & DIY Advice Manual versus automatic water addition for a steam system Wednesday at 6:02 AM
Plumbing Forum, Professional & DIY Advice Low water cut off series 67 Wednesday at 5:55 AM
Plumbing Forum, Professional & DIY Advice Where to place Tankless Water Heater Condensation Line Wednesday at 12:10 AM
Plumbing Forum, Professional & DIY Advice Add garden water valve/spigot to irrigation main line Wednesday at 12:09 AM
