Water Heater Space Problem
Discussion in 'Water Heater Forum, Tanks' started by Thomas D, Aug 29, 2013.
  1. Thomas D
    Thomas D New Member
    Aug 29, 2013
    Alabama
    The house we just purchased has 2 water heaters. One is almost new and is in the 1.5 story lever of the house.
    The other is 1985 model and we want to change it out. It is above the garage. The only way to get to it is up the pull down stairs. Ceiling joists are 24 inches on center. The water heater Rheem is 22 wide and 32 high and is 40 gal.
    Cannot find a 40 gal heater that will fit between the joist spacing and short enough to fit into the space due to the roof angle.
    Any ideas short of relocating the heater which would involve an electrician relocating the 220 line and plumber relocating the cold and hot lines?
    I have thought about going to a 30 gal heater which will fit, but am not sure if it will be enough hot water. I think the heater services the laundry and kitchen, which would be fine. Any way to tell what areas are serviced by this heater?
    Thanks
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Turn the valve off on the tank and see where there is no water coming out of the hot faucets.
    John
  4. dj2
    dj2 Well-Known Member
    Aug 13, 2013
    California
    A Reliance Lowboy measures 23" wide x 31.5" tall. It should work for you. You can find this brand at True Value.
  5. ImOld
    ImOld New Member
    Jun 1, 2013
    In the rumble seat
    Well, I know Lowes carries a Whirlpool 38 gal lowboy of the same dimensions as your Rheem because I pass by it in the store every trip.
  6. Thomas D
    Thomas D New Member
    Aug 29, 2013
    Alabama
    23 in wont fit between ceiling joists which are 24 in on center. I did see a reliance low boy that was 22 x 30 but it was a 30 gal. That might be enough depending on what it supplies.
  7. Thomas D
    Thomas D New Member
    Aug 29, 2013
    Alabama
    Will look tomorrow. Thanks. The only 38 low boy I see on Whirlpool site is 24 inches wide.
  8. Thomas D
    Thomas D New Member
    Aug 29, 2013
    Alabama
    Alas, there are no valves on either tanks hot water side. Have shut one off and will see where the lukewarm water is. With over 100 degree temps in attic it might take awhile. Hopefully, the old tank will be supplying the kitch, and laundry room. If so, then might just go to a 30 gal.
  9. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    The valve will be on the cold side and that will turn off the hot water.
    John
Similar Threads: Water Heater
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Wednesday at 10:49 AM
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
Water Heater Forum, Tanks Water Heater Leaking from the bottom. Feb 5, 2017
Water Heater Forum, Tanks Water Heater Choices Feb 5, 2017
Water Heater Forum, Tanks Richmond Water heater code 6 problem Feb 3, 2017
