Water Heater Anode Rod
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by edbreyer, Feb 12, 2005.
  1. edbreyer
    edbreyer New Member
    Oct 19, 2004
    Chicago
    I recall reading somewhere that water heaters have sacrificial anode rods that help reduce internal corrosion. Are these rods replacable in most heaters? I now have two Richmond/Rheem 50 Gal power vent heaters and with the new design (for flamible fumes) they're getting pretty pricey - so I'd like to take reasonable steps to extend their life.
    Any thoughts/suggestions?
    Thanks in advance!
    edbreyer
  2. Plumber2000
    Plumber2000 Plumber
    Jan 13, 2005
    Eugene, Oregon
    There replaceable, but to get them out is another story, they can be a bear to almost impossible to remove.
Similar Threads: Water Heater
Plumbing Forum, Professional & DIY Advice Water takes forever to heat up and it's close to the water heater Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Calculations for tankless water heater gas supply Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Small hot water heater solution? And related drainage question... Dec 21, 2016
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
Plumbing Forum, Professional & DIY Advice Do I need to create more of a electrical break for the hot water heater? Dec 4, 2016
