water heater anode + okay to empty tank + rotten egg odour
Discussion in 'Water Heater Forum, Tanks' started by francisg3, Feb 22, 2011.
  1. francisg3
    francisg3 New Member
    Feb 22, 2011
    Quebec, Canada
    Hello,
    I own a cottage in the northern part of Canada. The water supply here contains a lot of of metal, iron or magnesium I am told. I have an electric water heater and the hot water smells of rotten eggs. The cold water does not.
    I have read on the internet that it is possible to clean the tank out with some mixture of bleach and hot water. Is this recommended? Are there any other ways to get rid of the odour?
    From what I have been told changing the tank wo9uld solve the problem for a little while but the problem would soon return. Would it be okay to empty the tank when it is not going to be used? It would be empty for periods of about two weeks before being refilled. What effect wouldt his have on the anode rod?
    Any suggestions as to how to get rid of the odour would help.
    Thank you.
  2. jadnashua
    Change the anode rod to one of a different type and you'll probably get rid of the smell. The hard part is getting the old one out...an impact wrench or a big wrench and someone else holding the tank so it doesn't rotate is often required. If you don't have much room vertically, they sell 'segmented' replacement anodes that can be bent so you can install them. You may have to cut or break the old rod as you take it out (just don't drop it back into the tank!), since it is likely a single solid rod.
  4. Superduper
    Superduper New Member
    Apr 21, 2010
    my shop
    Suggest reading up on the various solutions on www.waterheaterrescue.com They recommend an Al-Zn anode, but also dosing the waterheater with hydrogen peroxide (NOT bleach) when the unit sits a long time. Apparently, there is bacteria that interact with the metals in the anodes metals that create the smell. You need the anode for corrosion protection, but the type of metal used makes a difference. Or you can kill the bacteria by H2O2 (hydrogen peroxide) temporarily, but likely to come back with time.
    I had this problem in a previous home; always would have to flush the waterheater after I didn't use for 3-4 days; became a ritual on returning to the house. It was OK when used constantly.
    Good luck.
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Change the Anode to an aluminum/zinc/tin anode and bleach the tank to kill the sulphur reducing bacteria...
Similar Threads: water heater
Water Heater Forum, Tanks Reducing 2 hot water heaters to 1. Monday at 2:01 PM
Water Heater Forum, Tanks Water heater has no drain pan, what precautions should I take? Mar 6, 2017
Water Heater Forum, Tanks Hot Water Heater Flame Temperature Mar 4, 2017
Water Heater Forum, Tanks Whirlpool 10 year old Water Heater Mar 4, 2017
Water Heater Forum, Tanks Gas Water Heater Explosion? Mar 4, 2017
