water backup in sewage line
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mongoose, Jun 5, 2011.
  1. mongoose
    mongoose New Member
    Jun 5, 2011
    nc
    i have sewage water backing up and coming out of the bottom of the floor on the downstairs toilet as this is the lowest point in the house... right outside the house 5 feet from this toilet a pvc wye with a cap it... when i unscrew the cap, water comes out as its about as high as the floor... is this more than likely a clogged main in my front yard(i have a tree) or could it be something more serious...its 3am now and just finished cleaning up the water from my last load of laundry and the pipe in the yard is full...is auger the way to go here...
  2. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    Yep, more than likely its roots from the tree. Auger then I always recomend having a camera inspection done after to see where and what the problem was.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Yep the line needs to be cleaned...
    As for what the problem is you never really can tell until the snake is in the pipe.
    Then it's an educated guess based on the drain cleaner's experience and skills.
    The camera inspection is a good way to know for sure...
  5. hj
    Auger it, but do NOT waste hundreds of dollars on a camera inspection, unless the plumber has a problem unplugging the line, OR it happens again within a few months. I MAY have videoed a dozen sewers in my lifetime, but ALL of them had serious problems and I had to know what or where it was.
  6. Redwood
    Dec 15, 2007
    Service Plumber
    As technology has gotten cheaper and more abundant there are many companies that now camera almost every main line they clean.
    Of course they are hoping they see something and can sell a repair....
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    One thing to avoid is trying to clear this with chemicals. Not only will they not clear the clog, they can create a hazard for the plumber you eventually will have to call to auger the line.
Similar Threads: water backup
Plumbing Forum, Professional & DIY Advice Waste water backup. Oct 22, 2016
Plumbing Forum, Professional & DIY Advice Need Advice Please Water Softener/Condenstate Drain Backup Issue Feb 1, 2014
Plumbing Forum, Professional & DIY Advice Odd vent pipe water backup problem Jan 24, 2013
Plumbing Forum, Professional & DIY Advice Floor drain backup - toilet water disappearing - possible Vent issues Jan 14, 2013
Plumbing Forum, Professional & DIY Advice Help!! Basement drain water backup Oct 30, 2012
