Washing Machine -Warm Cycle is not warm
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by IhavenoideawhatI'mdoing, Jul 13, 2009.
  1. IhavenoideawhatI'mdoing
    IhavenoideawhatI'mdoing New Member
    Jul 13, 2009
    We recently purchased a house with a washer.
    The warm cycle is not hot enough. Though it is slightly warmer than cold - the temp should be higher. (The hot and cold are fine).
    We were told there is nothing we can do about this - except to buy a different washer.
    Is there anything that can be done?
  2. CharlieNH
    CharlieNH New Member
    Jul 23, 2008
    Massachusetts
    Take off the hot water supply hose from the back of the washing machine and you may find a clogged screen filter where the water goes into the machine. That would be the easiest situation.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    My money is on the screen being clogged. I had a similar problem for some time after my dip tube went bad. I'd have to clean that screen periodically. Now I have a new water heater, the problem is resolved.
  5. hj
    warm
    If the hot and cold are fine, the problem is probably a clogged filter, or a bad timer, because to get warm water both hot and cold are opened by the timer. If both hot and cold have the same flow, and the hot is not too hot or cool, or the cold too warm or cold, you get "warm" water. You could have "cold" cold water, and "warm" hot water which could result in "cool" warm water, if that is not too convoluted.
  6. jimbo
    jimbo Plumber
    If the machine is located a long way from the water heater, then you will get a few gallons of cold water before the hot line sees hot water.
  7. seaofnames
    seaofnames DIY Senior Member
    Jan 25, 2009
    Boilermaker
    Mission, BC
    Especially if its a newer washing machine...lower water usage.
    Depending on the size of the house and pipe lay out, you might need/want to install a recirc system.
  8. ferd
    ferd New Member
    Mar 11, 2008
    Two options: Take a pliers and pull the screens out and replace with screened washers in the hoses or close the cold water valve enough to get the water temperature that you want! This isn't rocket science.
Similar Threads: Washing Machine
Plumbing Forum, Professional & DIY Advice How To Drain Utility Sink To Washing Machine Drain? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Help - washing machine hose and standpipe issue Jan 20, 2017
Plumbing Forum, Professional & DIY Advice Washing machine wall box suds backing up. Jan 5, 2017
Plumbing Forum, Professional & DIY Advice Washing machine inlet hose lifespan Dec 31, 2016
Plumbing Forum, Professional & DIY Advice Washing machine water feed shaking around Dec 31, 2016
