Washing Machine in Basement?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Erniek, Sep 21, 2008.
  1. Erniek
    Erniek New Member
    Mar 26, 2007
    Work..are you kidding?
    Greeneville TN
    Gentlemen, I just purchased a house with an 11 ft deep basement. Discharge to the septic is at the 10 ft mark, no other plumbing in the basement. I would like to put the washing machine in the basement. Can I use a small lift station set up or should I cut a sump pit in the floor? A pit would work but I hesitate cutting through the pour.
    Couldn't find this in the search....
  2. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Check the washing machine, maybe it will make the lift?
  4. jimbo
    jimbo Plumber
    What about draining the WM to a laundry tub?
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    A Liberty Model 405 would do very nicely in this application.
    [​IMG]
  6. jadnashua
    There are a couple of ways to interpret this, is the sewer outlet from the house one foot above the basement floor, or one foot from the ceiling?
    If it is one foot above the floor, most washing machines can pump high enough to get the required standpipe height and a trap. Now, installing the required vent could be a problem getting it from the basement to some point where you can tie into the rest - it might have to go up all the way to the roof.
  7. Erniek
    Erniek New Member
    Mar 26, 2007
    Greeneville TN
    The sewer discharge is 10 foot AFF...1 foot below floor joists. I think a pump is the only way...but I would like to install a utility sink also. Although there are no water problems now, I am wondering if a sump pit would be better in the long run. Thanks for the help
  8. Erniek
    Erniek New Member
    Mar 26, 2007
    Greeneville TN
    Thanks for the advice...You know I used to work with some plumbers out of Springfield Mass. years ago. The McCormicks I believe....mechanical contractor outfit. Boy those were some cold days!
  9. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Why wouldn't you just install a mechanical vent?
  10. Redwood
    Dec 15, 2007
    Service Plumber
    The pump system requires a through the roof vent. A mechanical vent offers one way ventilation, the pump system requires 2 way.
  11. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Couple points here. One is that if the sewer exits that close to the floor joists there isn't enough room to get a proper length stand pipe on. Second is the use of an AAV on a pump system. It won't work because the pump produces bocu pressure and aavs don't relieve pressure. In fact, if you install a pump without a proper vent the drain won't work because the incoming water pressurizes the tank. Most nasty when dealing with a washing machine.
  12. jimbo
    jimbo Plumber
    My bad on the sink suggestion....I thought the sewer was exiting 1' above the floor, and apparently it is 1' below the ceiling! Looks like pump and vent time!
  13. littlebrook
    littlebrook New Member
    Aug 14, 2008
    Not a plumber
    Rochester, NY
    I used one of these:
    http://www.amazon.com/Bur-Pumps-300514W-Laundry-Pump/dp/B000GA3PFG
    The burcam pump is similar in design to one made by Hartell called the LTA-1 but is about half the price. The Hartell pump is a little more powerful so you might want to consider that if your drain is 10 ft of the ground.
    Both pumps say that they do not need a vent. They come with a check valve to stop water flowing back into the pump. Mine is installed directly on a laundry tub and discharges into a 1 1/2 inch line that ties into the main drain line on the other side of my basement. Works fine so far. Just make sure you put some sort of lint filter in the laundry tub drain to stop the lint gunking up the pump.
    hope this helps
  14. Redwood
    Dec 15, 2007
    Service Plumber
    Phew...
    Not something I would consider...
    [​IMG]
  15. littlebrook
    Aug 14, 2008
    Not a plumber
    Rochester, NY
    Is there a reason why you would not consider one of these pumps?
    Not sure if it was the best solution but it was the most economical in my situation. When I bought my house, the previous owners had the washing machine discharging into the laundry tub which drained into the sump well. The sump pumped the water into the septic tank. This is against code where I live. Also, it made the sump well smell which was made worse every time I did a load of wash and churned up the contents of the sump.
    I looked into the "box and pump" solutions but those required a vent, something that I did not have in the basement. Then I heard about these pumps by searching the web and figured it was exactly what I needed. Installed it 4 months ago and has been working well ever since. No smells either despite the lack of a trap.
    Flotec also has a similar pump available at Home Depot (search for sink pump).
    I would recommend that you also pick up a flood alarm that will let you know if the pump stops working and the laundry tub overflows.
  16. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Because you still need to dump it into a vented trap.
  17. hj
    drain
    one thing you do not want is an open standpipe in the basement, if the sewer exits through the wall. If you have one and the sewer backs up ALL the water used in the house will overflow the standpipe.
  18. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    What about using a flapper check downstream from the standpipe and p-trap? This is what I do for water conditioning. I agree that you don't want a backup filling your basement:eek:
  19. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    You can't install a mechanical check valve of drainage.
Similar Threads: Washing Machine
Plumbing Forum, Professional & DIY Advice How To Drain Utility Sink To Washing Machine Drain? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Help - washing machine hose and standpipe issue Jan 20, 2017
Plumbing Forum, Professional & DIY Advice Washing machine wall box suds backing up. Jan 5, 2017
Plumbing Forum, Professional & DIY Advice Washing machine inlet hose lifespan Dec 31, 2016
Plumbing Forum, Professional & DIY Advice Washing machine water feed shaking around Dec 31, 2016
