Washing Machine Drain Backs Up-please help
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by EMcMahon, Sep 6, 2004.
  1. EMcMahon
    EMcMahon New Member
    Sep 6, 2004
    After over a year of putting up with this problem, I'm tired of it. My drain (where the water empties out during spin cycles) backs up whenever there's a spin cycle. The only time this doesn't happen is when I use a small load (only 1 or 2 pieces of clothing). I've snaked the actual drain that's in the floor, under the Washer and nothing has helped. Does anyone have advice for me? (A little history....we've only lived in this house 2 years this October and this problem started about 3 months after moving in. The house is over 30 years old). Should I just get a plumber or is there something I can do? :(
    Thank you for any advice.
  2. hj
    drain
    I think you have done all you can, so if you do not want to spend another year babying the drain, call a plumber.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    2 possible problems
    It could be that (1) the drain standpipe is too small. It should be 2", and if it is only 1-1/2", the washer could be putting out water faster than it can drain. (2) you may have a particial clog in the drain that is restricting the amount of water that can be drained at one time. In either case, you need a plumber to fix the problem.
  5. plumber69
    plumber69 Member
    Jun 20, 2014
    Prince Rupert, British Columbia
    Take picture. Home owners snakes are kinda useless. Could be simple if u have right tools
Similar Threads: Washing Machine
Plumbing Forum, Professional & DIY Advice How To Drain Utility Sink To Washing Machine Drain? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Help - washing machine hose and standpipe issue Jan 20, 2017
Plumbing Forum, Professional & DIY Advice Washing machine wall box suds backing up. Jan 5, 2017
Plumbing Forum, Professional & DIY Advice Washing machine inlet hose lifespan Dec 31, 2016
Plumbing Forum, Professional & DIY Advice Washing machine water feed shaking around Dec 31, 2016
