Washer/sink/dishwasher draining outside
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Pam Earls Groce, Jul 10, 2012.
  1. Pam Earls Groce
    Pam Earls Groce New Member
    Jul 10, 2012
    Texas
    I have zero plumbing experience but I will try my best to explaining my problem . Thanks in advance for any help!
    I have an about 2-3 inch. cast iron drain pipe ( ?) that sticks out of my outside brick wall of my house. I live in a single story home with a slab.
    This pipe is located under my kitchen sink. Whenever my washing machine, kitchen sink, and dishwasher drains, it all drains out of that cast iron pipe and onto the ground outside. Its now starting to smell like sewer!
    My washing machine is located in my garage which is right outside my kitchen door. I'm having no problems with any of my bathrooms draining. Both baths are located on the opposite side of my home.
    Where might a clog be that is causing my washing machine/kitchen sink/ dishwasher to drain outside instead of into the sewer lines?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The reason you are getting a sewer smell is that is what you have. I have no idea what that pipe was originally for, but certain not a drain. You need a professional to deal with this. There is no way that you should ever have a pipe draining like you describe. You are right about there being a clog somewhere, but a clogged drain is not a DIY fix either and your problem is more than that anyway.
  4. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    It could be a clean out that the plug is missing on. The line may be clogged and the water is backing up and coming out the open line.
    John
Similar Threads: Washer/sink/dishwasher draining
Plumbing Forum, Professional & DIY Advice Bathtub drain not connected to drain pipe; bathwater draining into foundation Feb 4, 2017
Plumbing Forum, Professional & DIY Advice Kitchen sink not draining correctly Jan 12, 2017
Plumbing Forum, Professional & DIY Advice Draining into Sump Pit Jan 7, 2017
Plumbing Forum, Professional & DIY Advice Please verify my proposed re-venting/draining for washer Dec 9, 2016
Plumbing Forum, Professional & DIY Advice Dishwasher draining problem! Nov 5, 2016
