Want to add new insulation to basement
Discussion in 'Remodel Forum & Blog' started by alexjag33, Mar 28, 2007.
  1. alexjag33
    alexjag33 New Member
    Jan 13, 2007
    I've framed my basement and now need to add insulation.
    I've read one book that says to put up fiberglass batts and then install a plastic vapor barrier. I'm told by other sources that this method encourages mold and is no longer the preferred method.
    Another book I have says the "new method" is to put up foam insulation panels right up against the concrete walls, and then put up the studs in front of it. Well, since I've already framed, it's too late for this.
    What would you guys recommend I do now? It's so confusing to know who is right.
  2. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    climate and construction
    factors determining the right way to do it are: your climate, and how the building was built.
    Foam is both a vapor barrier and insulation. Foam is recognized as a smart way to insulate. Read the current version of http://en.wikipedia.org/wiki/Building_insulation_materials
    david
  4. alexjag33
    Jan 13, 2007
    Need more info
    Can you be more specific?
    "Foam" covers about half of the Wiki page you linked to. Which type of foam are you recommending?
  5. geniescience
    Nov 27, 2005
    ditto
    no i cannot. All foam is good. You can buy the cheapest.
    david
  6. geniescience
    Nov 27, 2005
    ditto
    Using your same skills that brought you here, websearching, in general, before EACH time you post a new post, you do some homework and background work and searching and thinking and reflecting, and you get some information and / or answers somewhere else or at least from othre threads here -- and then you share this while you ask for new input.
    Also, you answer the questions others asked you to answer.
    I mentioned climate, and it is good to know this info, and more. E.g. is the basement wet or dry. The more you provide, the more likely it is that you will get the right info in return.
    Doing this will encourage senior participants to keep coming back to read each new post, and to help you in many ways.
    My opinion, which I have not tried to turn into a "policy".
    -david
  7. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    There are many factors that can come into play here, and you might consider calling out an insulation saleman/engineer/estimator from a reputable company to do an assessment.
    In my own experience, basements tend to be damp, especially during summers, and I deal with that dampness (condensation) in my own basement by using a dehumidifier ... and that can even help with a dampness problem of water actually coming in through block walls ... and no "vapor barrier" is ever going to eliminate either.
    Think of a raincoat as a "vapor barrier" to protect your clothes underneath, then ask yourself what you are trying to "protect" in your basement, and just how you are also going to deal with the "rain" on the other side of that barrier ... then imagine your house going swimming while wearing a raincoat.
    Personally, I say just forget the "coat" (barrier) and dehumidify!
Similar Threads: insulation basement
Remodel Forum & Blog Finishing Basement - Doubling the wall insulation Thursday at 1:13 PM
Remodel Forum & Blog Walkout Basement Insulation/vapor Barrier Question - Pic Included Apr 27, 2016
Remodel Forum & Blog Basement insulation options Mar 2, 2016
Remodel Forum & Blog Basement floor & wall insulation with perimeter drain Jan 21, 2015
Remodel Forum & Blog Advise asked on basement wall insulation and fire blocking Jan 15, 2015
