Wall-mount with floor-mount look?
GoBeau
I am renovating my master bath and must install a wall-mount toilet. However, I don't like the look of them; I feel that they look very industrial. Is there any wall-mount toilet on the market that has a base like a floor-mount? Or, is there a way to create a base for a wall-mount? Thank you!!!
outlet
The problem you may find is that while there is a "standard" above the floor measurement for the wall hung outlet, there is no requirement that it be used. In other words the toilet can be mounted higher or lower than standard, but the floor mount back outlet bowl has no latitude. If the hole in the wall is higher or lower than the toilet's it will not fit.
e-plumber
DIY Senior Member
New York
Floor Mount / Rear Outlet
You can always rough in the drainage for the American Standard Yorkville, pretty good looking toilet.
D
dc_homeplumber
Guest
If I'm not mistaken, the Yorkville is Pressure Assist -- excellent, though a little noisy.
