Walk-in Shower
Discussion in 'Shower & Bathtub Forum & Blog' started by Sheffey, Jul 15, 2008.
  1. Sheffey
    Sheffey New Member
    Jul 15, 2008
    Hello! I have a dilemna. I want to install a walk-in shower and I need to know what plumbing materials are necessary for the job. What goes underneath the floor to insure that no leaks occur? Please help.
  2. jimbo
    jimbo Plumber
    This is a pretty broad question. Do you mean a shower with a curb, or one you could roll a wheelchair into?
    In any event, a waterPROOF liner must be under the tile. There are a number of special requirements.....the subfloor must first be pre-sloped to allow water to run to the drain. Then the waterproof membrane goes down...PVC, copper, or lead. These materials take some knowledge and skill to put down. Then a mortar sub-base goes down, and the tile on top of that.
    The membrane must be continuous up and over the curb, and about 8" up the wall.
    A good reference is the "Ceramic Tile Handbook" from the Tile Council of America ( tileusa.com)
    Another excellent resource is the tile forum www.johnbridge.com
    I do recommend that you get some books and do some study. Right now you don't even have a basic understanding to ask relevant question. There is a lot of help available here on the internet, but we can't build it for you.. You have to take the lead.
    By the way, there are some more modern waterproofing systems than those I mentioned, so if you go into a tile specialty store, you can probably get some reference material and training about those.
  4. jadnashua
    Check out www.schluter.com on Kerdi...it is well suited to waterproof that type of shower and floor area. Noble company makes a similar, but probably a little harder to work with membrane. These are easier than the conventional liner since you only need the slope...then you install the liner membrane and tile directly to it. The conventional liner needs additional mortar on top of it to tile to, and results in a thicker total shower pan - makes it harder to do a barrier free shower, especially if it is a retrofit.
  5. rolls831
    rolls831 New Member
    Jul 5, 2008
    Santa Cruz, CA
    walk in shower
    If you want a shower pan that won't leak and can be tiled the same day you install it. Go to Tileredi.com. It has a 6" threshold. They supply the special thinset for the tile in the pan, it's called Latapoxy-300 Epoxy Adhesive. I'll be installing one that is 33x60. LOL.
  6. jadnashua
    There are other pans/systems that can be tiled the same day as installed. Another system, as opposed to a component that works well is Wedi.
  7. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Post(s) removed by John Whipple
  8. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  9. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
Similar Threads: Walk-in Shower
Shower & Bathtub Forum & Blog Drain and faucet position for walk-in shower Oct 23, 2013
Shower & Bathtub Forum & Blog WEDI walk-in shower base construction Apr 3, 2011
Shower & Bathtub Forum & Blog Walk-in Tile Shower help May 7, 2009
Shower & Bathtub Forum & Blog Replacing tub with walk-in shower Jun 14, 2006
Shower & Bathtub Forum & Blog Doorless walk-in shower Jan 25, 2005
