Voltage drop in underground cable
DonL
Houston, TX
We used to fix Gophers with a .410 Shotgun or .22 rifle, works good and last a long time.
Preventative Maintenance is a good thing.
DonL
Houston, TX
Gentlemen I would like to thank you all for your input I walk the path of the wire and found what appeared to be a gopher hole I dug up the wire at that point and found a small nip in the wire. I cut that section out and reconnected the ends and have 120 volts at gfi receptical. Thx again for your suggestions.
Good Deal.
I hope you sealed the splice properly.
Did it kill the gopher ?
I bet probably not, Gophers do not go by the NEC rules.
BobL43
DIY Senior Member
Long Island, NY
Good Deal.
As long as the gopher did not test the wiring with a light bulb before chewing on the wire, he should be OK. If he used a bulb, then who knows? We have lots of Moles here on Long Island
DonL
Houston, TX
Can Moles See ?
LOL.
If there was a Lightbulb in the circuit it could have limited the current to 1 amp instead of the 20 amps from the breaker.
Gophers and Moles like Lightbulbs for a Zap protector.
Moles cant see Light, Or can they ?
BobL43
DIY Senior Member
Long Island, NY
LOL.
Good thing they can't see us. They might think we are ugly like we think they are
Ballvalve
northfork, california
I hope your kid does not dig in gopher holes with garden tools and hammers like mine. Your next dead gopher may have tennis shoes on and a tee shirt.
DonL
Houston, TX
I guess that is were the old Tonka Toys should be buried.
