Fletch1
During a bath remodel I had a pro come in to help with plumbing. As it turns out it's a disaster. I can't have him back again. There are 2 bathrooms one above the other. A sewage pump up ejector was installed in the lower bath years ago, it was vented to the main horizontal vent in the upstairs bath. When the plumber came to plumb the upstairs bath he looked at the ejector etc and told me the ejector vent was not needed. So he tied upstairs bath sink drain into it.
The problem I'm having now is the upstairs sink rough in drain is to high for are 32" pedestal. The wall is tiled so I can't lower the drain on the bath side. I have opened the wall on the kitchen side and after looking things over I'm not sure how to approach this.
An earlier photo shows the plumbers rough in sink drain ties into the sewage elector vent, which I believe makes it a wet vent between bathrooms on different floors. I have been told that's not allowed. Maybe he did this because as he said the "ejector vent was not needed" so he felt he could just use it as a drain?
So in any case I need to lower the drain and there is a hole in the floor that I can access for that purpose but venting it is not an easy option. So can you tell me if it can share the with the kitchen sink vent which is close by? Or if the ejector vent is not needed as the plumber said I just lower the drain and tie into ejector vent?
Here the photo's link, 2nd photo is the kitchen side. Thanks for your help.
https://www.screencast.com/t/Q38dea9z7
https://www.screencast.com/t/0zR0h8khy
