Vent questions
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by geekette, Oct 7, 2005.
  1. geekette
    geekette New Member
    Oct 7, 2005
    North Carolina
    I was sent here from the John Bridge forums for a little help. I obviously don't know anything about plumbing, so I hope this will make some sense...
    We're redoing our master bath, including removing a tub and moving the toilet to essentially where the tub was. The plumber wants to remove a major vent that used to service the double vanity and toilet (which will now, I guess, tap into the old tub vent). He says there's a type of vent that's used now under the sinks (schrader?) so the sink drains don't have to tap into the vent that goes through the roof.
    I could have this all wrong, but I'm hoping someone here will have a clue what I'm talking about. The vent could be moved into the wall with some difficulty, but I think he just wants to get rid of it.
    The toilet's moving about 7-8' so he's having to tear up the floor and run the drain (properly sloped, I hope) to the existing drain. He also said he'd insulate the new drain so we don't have a lot of running water noise in the kitchen below.
    Does this sound...okay?
  2. jimbo
    jimbo Plumber
    Air Admittance Valves ( Studor is the brand ) are allowed by some but not all codes. Many plumbers are basically skeptical about using them because they are a mechanical device with moving parts and rubber seals, and by defintion will sooner or later fail. There is always an alternative to using these, but the alternative is not necessarily easy or inexpensive.
  4. alhurley
    alhurley Guest
    [​IMG]
    Oatey also makes them
Similar Threads: Vent questions
Plumbing Forum, Professional & DIY Advice Bathroom planning advice (venting questions primarily) Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Shower Retrofit Project: Drain and Venting Questions Nov 23, 2015
Plumbing Forum, Professional & DIY Advice New bathroom venting questions - w diagram Jul 11, 2014
Plumbing Forum, Professional & DIY Advice Venting Questions for the Pros Apr 30, 2014
Plumbing Forum, Professional & DIY Advice Gas Dryer Vent Questions Feb 16, 2014
