Vapor barrier under carpet pad
Discussion in 'Remodel Forum & Blog' started by bmw220, Aug 7, 2008.
  1. bmw220
    bmw220 New Member
    Aug 3, 2008
    Is it a good idea to lay down a sheet of plastic (polyethylene) under the carpet pad when installing carpet on basement concrete floor? The pad I am getting has vapor barrier between the carpet and pad.
    Another possibility is to coat the floor with drylock. I am incliened towards the plastic sheet because of less labor, but if it turns out that sheet is not a good idea, I will use drylock.
  2. D.Smith
    D.Smith New Member
    Feb 6, 2007
    I would advise against any type of pad/vapor pad in a bsmt situation. Its a given fact that all bsmts below grade will get wet. By placing a pad/vapor pad under the carpet will contribute to larger cost in restoring.
    If your inclined to pad your basment drylock the cement. Leave the pad with the vapor barrior for a pet situation. If you have moisture under the vapor barrior wouldnt you want to know about it? Not only will it keep water from soaking into the pad it will keep water from coming into the carpet.
    IMHO Dryloc and carpet glue down.
Similar Threads: Vapor barrier
Remodel Forum & Blog Walkout Basement Insulation/vapor Barrier Question - Pic Included Apr 27, 2016
Remodel Forum & Blog Subfloor question about vapor barrier Dec 2, 2015
Remodel Forum & Blog Vapor Barrier or Not Dec 28, 2013
Remodel Forum & Blog Vapor barrier with new shower Nov 3, 2011
Remodel Forum & Blog Completely confused about vapor barriers for bathroom Jul 7, 2011
