Valve Does Not Open
Discussion in 'Irrigation / Sprinkler Forum' started by jomama, Dec 15, 2008.
  1. jomama
    jomama New Member
    Dec 15, 2008
    Retired
    Florida
    My neighbor has a six zone Hunter sprinkler system and the 1 inch valves on zones 1 & 2 do not open. The solenoids are getting power and I have disassembled the valves, cleaned them, and reassembled them, and still no luck. Even when I unscrew the solenoids, they still do not open.
    I'm "dazed and confused"................
    Eureka!!!! When cleaning the valve, I didn't notice another vent/orifice directly under the solenoid plunger. It didn't look like there was an opening because it had sand in it!!! I found a thin wire and shoved it through the opening, and the sand came out at the tip of the wire. I reassembled the valve and it works like a charm!!
  2. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    If the solenoids don't actuate, they aren't getting enough current. Suspect poor wiring.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Look especially closely at the ground wire. The usual way to connect a series of valves to ground is to daisy chain them. There could be a loose connection in the links.
Similar Threads: Valve Does
Irrigation / Sprinkler Forum new valve doesn't work May 30, 2012
Irrigation / Sprinkler Forum Sprinkler valve doesn't appear to close Sep 10, 2009
Irrigation / Sprinkler Forum how does electric sprinkler valve work? Jul 3, 2006
Irrigation / Sprinkler Forum How to know which zone on valve goes to which sprinklers Sunday at 3:14 PM
Irrigation / Sprinkler Forum Valve Box Too Low - Should I Stack Boxes? Jan 31, 2017
