Using springwater for heatpump source
Discussion in 'HVAC Heating & Cooling' started by Ridgeview Farm, Feb 22, 2010.
  1. Ridgeview Farm
    Ridgeview Farm New Member
    Feb 22, 2010
    kirby vermont
    I have a three -tile spring that prodices about 5 gallons/min and a storage capacity of 262 gallons. It produces 15-20 psi at the house(it sets above the house about 75 feet. I have investigated the needs of a 5 ton unit (about 1.5 gal/ton). What I cant find is how long will a typical run of the heat pump be..ie. between storage and gpm can I use the spring water to run this system.I do have to check on the temperature again, But other wise???
    Any suggestions?
    Tom
Similar Threads: Using springwater
HVAC Heating & Cooling Indoor sauna causing humidity issues Dec 1, 2016
HVAC Heating & Cooling How to control the heat using the thermostat? Nov 20, 2016
HVAC Heating & Cooling BTU Estimation (using App) seems high? Jul 28, 2016
HVAC Heating & Cooling Backed up drain (condensate?) line still after using shop vac Aug 30, 2015
HVAC Heating & Cooling Unbalanced oil supplyline due to de-aerator? Air causing one burner to cut out. Dec 26, 2013
