Using existing tub water/drain for sink
Discussion in 'Shower & Bathtub Forum & Blog' started by Fidget, Oct 17, 2009.
  1. Fidget
    Fidget New Member
    Oct 17, 2009
    Retired
    virginia
    Im installing a wet bar sink on the backside of an existing bathroom wall that has access to the tub overflow drain pipe as well as the 3/4 water pipes serving the tub from the main. I want to T the sink drain off the overflow drain coming from the tub and run the water off the tub water pipes. I dont know if this is to code or not. The sink drain trap and vent (interior) will be prior to drain pipe entering the wall and doing a 90 degree down to the overflow pipe on the tub. If T ng into the O/F drain is not good, I have, close by and accessible, a 4 inch sanitary stack with clean outs that I can tap as well. Again, dont know if this is doable via code. I live in Virginia and will be going to the County offices on Monday. Just want to know if Im in the ball park.
    Fidget
  2. hj
    drain
    Neither one should be acceptable to the building department, but for different reasons.
Similar Threads: Using existing
Shower & Bathtub Forum & Blog Repl shower head using fpt coupling--Plan C:can't catch a break Jan 31, 2017
Shower & Bathtub Forum & Blog Bathroom faucet water leak - faulty faucet using both lines Sep 2, 2016
Shower & Bathtub Forum & Blog Renovating and reusing 'princess tub' Jul 7, 2016
Shower & Bathtub Forum & Blog Diverter Spout Drips While Using Shower Head Oct 20, 2015
Shower & Bathtub Forum & Blog whines when using hot water in shower Feb 19, 2015
