Upstairs Kitchen sink draining into basement kitchen sink
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DIYRENO, Jan 17, 2012.
  1. DIYRENO
    DIYRENO New Member
    Jan 16, 2012
    Saskatchewan
    Hello,
    We are renovating our basement. There currently is a sink in the basement below the upstairs kitchen sink. When you drain the sink from the kitchen upstairs it drains into the sink below before draining. It has an AAV approx 4 inches from the P-Trap. If I removed the AAV and vent the basment sink directly would this solve my problem.
    Any help is appreciated
  2. hj
    ddrain
    If the top drawing is what you intend to do, forget it. That "vent" would do nothing to solve the problem. The AAV cannot prevent positive pressure problems but that is not what you have. You have a plugged drain and until it is cleaned the problem will continue, with or without the AAV. one side note, a vent that turns sideways is not a "branch vent" it is a "horizontal section of a vent stack".
  4. DIYRENO
    DIYRENO New Member
    Jan 16, 2012
    Saskatchewan
    Thanks for the information. Yes the top was what I planned to do and the bottom is what is existing. We did snake the drain when we first moved into the house but did not have it done professionally so I guess that is the next step.
    Appreciate this site..
  5. jadnashua
    Two things: the AAV should be higher, and once a line becomes a drain, it can't be a vent. To properly vent the lower sink, you'd want to run a new vent up above the upper sink by at least 6" or 42" from the floor, whichever is higher. If the drain line isn't plugged or restricted, if the aav was a bit higher, that may pass code. You want the aav as high as possible if in a cabinet and still be able to remove it, or if possible, above the flood rim of the sink.
  6. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Well the top picture is just plain bad plumbing practice and adding the AAV may solve the problem but even with the bad plumbing practice the reason the sink is draining into the lav is because the drain below is plugged or partially plugged.
  7. hj
    AAV manufacturers show the valve 6" above the drain line. Once the "vent becomes a drain", any "vent" is useless until the water drains out anyway.
Similar Threads: Upstairs Kitchen
Plumbing Forum, Professional & DIY Advice Can i install a kitchen sink upstairs into washing machine drain directly below Mar 7, 2016
Plumbing Forum, Professional & DIY Advice Unstopped upstairs tub now downstairs kitchen spewing debris. What's going on?? Dec 30, 2012
Plumbing Forum, Professional & DIY Advice Washing machine suds from upstairs draining into kitchen sink May 12, 2011
Plumbing Forum, Professional & DIY Advice Kitchen sink Gurgles when upstairs toilets are flushed Feb 10, 2008
Plumbing Forum, Professional & DIY Advice Low water pressure upstairs Jan 24, 2017
