upstairs bathroom into sump pump
ysobored25
Hi all,
I currently have an upstairs bathroom sink pvc line draining directly into the basement sump pump. The previous owner didn't want to fool around with the cast iron that fed directly into the sewer line so he went the other route of directing the pvc to the sump pump. Can anyone give an opinion if this is dangerous or not correct. I don't want to overtax the pump.
Thanks
I doubt that would ever pass an inspection...I think you should fix this.
Master Plumber Mark
www.weilhammerplumbing.com
nothing new
seen much worse, people dumping their laundry drains into the sump pump
that went ouit into the back field.......
it would be nice to change it someday, but being probably only a few gallons of water a day with toothpaste and mouthwash ect going into it its not a critical problem... put it on the something to do list
but on the bright side, the sump pit probably smells "minty fresh"
pump
If depends on where the sump pump is discharging. If it is connected to the sewer system, then it was a dumb idea, but it will work. If it goes into the yard then it was both a dumb idea and illegal.
Master Plumber Mark
illegal things
Once, on a farm, we ran into a situation where
the old farmer just installed a large drum out into the back yard with a pipe off of it going down a few hundred yards away to the
"gulley" ---- small stream.
this was his version of a septic tank.....
it had basically been dumping raw sewage out in the back 40 for years and years.
Basically it was a trash heap with cars ect laying in it, you didnt hardly notice any smell.
Eventually they wanted to sub divide the property.
when the inspector did a sewage tank inspection, things got real ugly.
