aminm
Hello folks
Kindly help me with regards to UPC code work realted questions . Ihave been given an assignment by my workplace to find out where in UPC the following are mentioned
1- No portion of the drainage system underground or below a floor slab , basement or cellar shall be less than 2 inch(50mm oD)nominal diameter .
2- Drainage pipe for condenste waste from airconditioning cooling units shall be indirectly conected to a floor drain or shall be indirectly connected into the inlet side of a P trap .
3- No acid or chemical wastes shall be discharged into the ground or local sewer without the approvla of the Chairman of Plumbing and Utilities stds committee
4 - In remote areas where no sewer or drainage lines are close by the waste system shall have prinmed traps and primed traps and piped to a dry sump .The system shall be vented .
Kindly help
TIA
Kindly help
TIA
